Question about Nokia 5120
Where is the place where the sim card slot is located in a nokia 5120?
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
I'm sorry to inform you that this phone (manufactured in 1998) is an analog GSM phone. (Read - Not Digital)
Because it is an analog phone, there is no cellular service provider that you can activate or use this phone with.
This phone does not use a SIM card. It was manufactured before SIM cards were used in GSM phones. Specifically, this phone was manually programmed to a specific analog cellular network - and analog networks are no longer used.
Posted on Mar 27, 2011
No sim card
Nokia C3 mobile shows no sim card means:
1.Might be your sim card got corrupt
2.Sim card slot in your handset may be damaged
3.Sim IC got damaged
these all are the reason for this problem
soluion
1.Check your sim on other mobiles.
2.Change you Sim slot after checking it.
3.Lastly check your SIM IC if neccesary change it
Aug 17, 2011 | Nokia C3 Cell Phone
Nokia 5310 shows start up phone without sim card? accept or reject but there is no any problem with sim card it works inserting into other phone.
If the sim card works on other phone , it means to say the problem lies on the phone.
Check the sim card slot and try to check for any dust.
You may want to check if the sim card is properly place or inserted.
If in case still doesnt work try to use other sim card, if still the same thing bring to mobile technician.
May 26, 2011 | Nokia Cell Phones
I have problem to my phone (N73), if i insert sim card to slot sim card my phone (N73), it show msg "sim card not valid"... any solution to my sim card problem
Hi
please do these tips :
insure that your SIM card working properly test it in another phone
if it work so clean the SIM card place , and test it while you push the battery to keep SIM in its place .
if that don't help try to software the device .
if that don't help so you must check about SIM driver(IC connect SIM base with CPU).
I hope that helps you
Apr 25, 2011 | Nokia N73 Music Edition Smartphone
My nokia 6700 slide is stuck in off line mode and then it said insert sim when the sim is already in are you able to help. george
What can I advise you is to check if the SIM card is properly connected to the card slot and make sure that this is properly attached. You can also try to use an eraser and rub it to the metal plate of your SIM card first to clean the metal plate before placing it to the SIM card slot.
Mar 18, 2011 | Nokia 6700 Slide Cell Phone
Nokia 5130 rejected my sim?
hi,
there are many reason for that,
1) loose sim card. try removing your sim card and place it again securely to the slot.
2) defective sim card. try replacing another sim and see if it works.
3) bad terminal contact. if you can manage to see your sim card terminal in the phone, try checking it if their is no abnormalities in it.
4) the worst is that it has a defective sim card IC. (rare case)
Hope i helped you.
Don't forget to rate me OK!
regards,
John
Jan 04, 2011 | Nokia Cell Phones
How to place Sim how to open
The SIM card slot is located at the right panel of your device. Below the SIM card slot, you will find the storage card slot. The battery compartment is located at the back side of your device.
You will be able to download the user manual for your HTC Phone from the link below.
Download Manual
Download the manual and it will show you how to use the smartphone.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HTC Touch P3450 Smartphone
Nokia 5130 insert sim
Initially try by cleaning the sim card slot.
The insert sim card happen due to the problem in Sim card holder slot and the IC related to it.Contact the service center they will check the sim card slot and provide you a solution either by cleaning the slot and PCB board or replacing IC
Jul 08, 2010 | Nokia 5130 Cellular Phone
How to put sim card in nokia 1661 phone.
On the majority of mobile phones the SIM card slot is located under the battery. Remove the back cover and the battery to reveal the SIM slot. The SIM card has a chamfered corner and this must be placed into the slot to match the chamfer.
Jan 13, 2010 | Nokia 1661 Cell Phone
Open Questions:
Nokia 5120 Logo
85 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
