Question about Crossfire CF212D Car Speaker
How to use dis - Crossfire CF212D Car Speaker
  • 314 Answers
Hi janrenz87,
Just read the Manual that came with those speakers and it should have instructions on how to use and install into your Car.
i hope this helps.
Posted on Mar 27, 2011
What is a prefix meaning of dis for disloyal?
"dis" here means "not" as in "Not loyal"
Dec 10, 2015 | Vehicle Parts & Accessories
How to adjust distributor timing on a 280e mercedes 1984 model
locate distributor,look at where dis. goes into engine block, should be a horseshoe type clamp holding the dis. shaft in place, loosen bolt til dis moves, start engine, with timing light pointed at timing mark on front of engine, turn dis. slightly to increase timing up or down, when in right spot, turn off engine,tighten bolt, put a mark on base of dis. n engine block to check in future, to see if dis. moves.
Apr 17, 2014 | Vehicle Parts & Accessories
. said a new dis. plus shims or th e new dis. would not last? also engine starts fine but dies immediately there after Thomas
said a new dis im not sure what that means who said dis??
Do you have fuel press? the spider gear for fuel goes a lot in blazers.
also check iac motor reading.
Jan 05, 2012 | Chevrolet Blazer Cars & Trucks
Hey there,i have a 1991 msuatng LX with the 2.3L ho engine running an 8 plug head. it sounds like i may have a misfire of some sort or my timing may be out but im not sure how to tell, could someone give...
Insert each wire on the proper terminal of the ignition coil. Ensure that the coil boots are fully seated and both locking tabs are engaged. The terminals are identified on the ignition coils. Install wires as shown in the illustration. The 2.3L firing order is 1-3-4-2 for both ignition coil assemblies.
Distributorless Ignition System In the distributorless ignition system (DIS), all engine timing and spark distribution is handled electronically with no moving parts. This system has fewer parts that require replacement and provides a more accurately timed spark. During basic operation, the EEC-IV determines the ignition timing required by the engine and a DIS module determines which ignition coil to fire.
Components
The distributorless ignition system (DIS) for the 2.3L twin spark plug engine consists of the following components:
  • Crankshaft timing sensor
  • DIS module
  • Two ignition coil packs
  • Spark angle portion of EEC-IV
Crankshaft Timing Sensor
The crankshaft timing sensor is a dual hall effect magnetic switch, which is actuated by the dual vane cup on the crankshaft pulley hub assembly. This sensor generates two separate signals, PIP (profile ignition pick-up) and CID (cylinder identification). The PIP signal provides base timing and RPM information, while the CID signal is used to synchronize the ignition coils. Initial timing (base timing) is set at 10 degrees BTDC and is not adjustable. Ignition Coil Packs
Two ignition coil packs are used for the 2.3L dual plug engine. The two ignition coil packs are triggered by the DIS module and are timed by the EEC-IV. Each coil pack contains two separate ignition coils for a total of four ignition coils. Each ignition coil fires two spark plugs simultaneously, one spark plug on the compression stroke and one on the exhaust stroke. The spark plug fired on the exhaust stroke uses very little of the ignition coils, stored energy, and the majority of the ignition coils, energy is used by the spark plug on the compression stroke. Since these two spark plugs are connected in series, the firing voltage of one spark plug will be negative with respect to ground, while the other will be positive with respect to ground. Refer to thePowertrain Control/Emissions Diagnosis Manual for additional information on spark plug polarity. DIS Module
The main function of the DIS module is to switch between ignition coils and trigger the coils to spark. The DIS ignition module receives the PIP and CID signals from the crankshaft timing sensor, and the SPOUT (spark out) signal from the EEC-IV module. During normal operation, PIP is passed on to the EEC-IV module and provides base timing and RPM information. The CID signal provides the DIS ignition module with the information required to switch between the coils for cylinders 1 and 4 and the coils for cylinders 2 and 3. The SPOUT signal (from the EEC-IV) contains the optimum spark timing and dwell time information. The dwell time is controlled or varied by varying the duty cycle (duration) of the SPOUT signal. This feature is called CCD (computer controlled dwell). Therefore, with the proper inputs of PIP, CID and SPOUT the DIS ignition module turns the ignition coils on and off in the proper sequence for spark control. CID is also sent to the EEC-IV micro-processor to allow for Bank to Bank fuel control. Failure Mode Effects Management
During some DIS system faults, the Failure Mode Effects Management (FMEM) portion of the DIS ignition module will maintain vehicle operation. If the DIS ignition module does not receive the SPOUT input, it will automatically turn the ignition coils on and off using the PIP signal. However, this will result in fixed spark timing (ten degrees BTDC) and a fixed dwell time (no CCD). If the DIS ignition module does not receive the CID input during engine cranking, random coil synchronization will be attempted by the module. Therefore, several start attempts (cycling the ignition from OFF to START) may be required to start the engine. If the DIS module loses CID input while engine is running, the module will remember the proper firing sequence and continue to fire to maintain engine operation. Dual Plug Inhibit
Dual Plug Inhibit (DPI) is a function of the EEC-IV that is only used when the vehicle is being started at temperatures -7° C (20° F) and below. During engine cranking, the EEC-IV will only fire the spark plugs on the right hand side of the engine. When the engine has started, the EEC-IV will send a signal to the DIS module to start normal dual plug operation. Ignition Diagnostic Monitor
The Ignition Diagnostic Monitor (IDM) is a function of the DIS module. The DIS module sends information on system failures to the EEC-IV which stores the information for diagnostic self test. The IDM signal also is used to drive the vehicle instrument tachometer, and test tachometer for system
Nov 19, 2010 | 1991 Ford Mustang
How do you set clock on a jensen VR185?
Hold "dis" until hours flash. Use volume knob to adjust. Press "dis" again to move to minutes. Press "dis" again to exit.
Oct 21, 2010 | Jensen Car Audio & Video
I have (SAMSUNG Corby Color)SAMSUNG GT S3653 mobile. I have problem while using touch screen. When I scroll, option get selected. I have tried scrolling on other SAMSUNG model. But there is no problem...
Dis iz bec touch screen is very much sensative.Try using it with sm care i also had dis problem earlier bt nw its f9.
Do not hold any option 4 long...Dis is d only solution 2 dis
Aug 14, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Dvd video keeps telling me there is no dis , why
hello,
the reason the dvd palyer is not reading disc is actually because the lens is weak, if you get it replaced it would read disc perfectly.
Feb 04, 2010 | Televison & Video
Hi dis is srikanth , my I phone 2 G touch screen
bro replece ur screen system then its working
Dec 01, 2009 | Apple iPhone Smartphone
I am having a hard time pairing my Bluetooth to my Ford Focus 2008 to Sync. I cannot pair the phonebook. I have tried unpairing and repairing but nothing works.
hi karen dis is joahna nerry tampus i want to get dis cellphone..
manny people sending me a free cell phone in friendster..
i want to get dis..
my address is 2795 luzviminda st. timog caa laspinas city..
and im joahna nerry tampus.. i hope i get dis cell phone.. thnak you...
Aug 18, 2009 | LG Vu CU920 Cellular Phone
I can't open my yahoo mail
always i tried to open my yahoo mail it gives a requested url
Aug 17, 2008 | Yahoo YHT-630 System
Crossfire CF212D Car Speaker Logo
Top Crossfire Car Audio & Video Experts
Morne Olivier
xxxxxx xxx
Rommel Balcita
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
