Question about Onkyo TX-SR502 Receiver
When connecting optical inputs there is no audio output
    Brigadier General:
  • 8,546 Answers
You have to assign each digital input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR502-Receivers-manual/id/365ag217/t/2/
Search the document for "assign".
Posted on Mar 27, 2011
2 Suggested Answers
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Does this system have a optical input
Here are the list of connections on this system
• Audio inputs/outputs 2 analogue input sources,
1 analogue output connection
- TV : in
- VCR : in
- CDR : out
- Headphone : 3.5 mm
• Digital audio in/output : 2 digital output connection
(coax, optical)
• Video outputs : 3 output connections (1 S-Video)
- TV : out
- VCR : out
- Monitor : out
• Speaker Connections suitable for speakers ≥ 6 Ohm
- left, right, center : click-fit connection
- rear left, right : click-fit connection
• Miscellaneous connections
- TV center speakers pre-out : 1
- Subwoofer pre-out : 1
- AM antenna : loop type
- FM antenna : coax
please mark this fixya if it has answered your question.
Dec 14, 2009 | Philips LX3000D System
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
Jul 06, 2009 | Denon AVR-3805 Receiver
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Dear wayne,
Please locate audio input socket on your TV, Then Connect audio output of DVD recorder to this input socket. The optical output of TV goes to input of amp. Since the DVD recorder is connected to the TV and TV's out put connected to the Amp. Now the sound signals from tv and as well from DVD will be 5.1 surround from the amp.
If any case this does not solve your problem, please mail me the photo of the back side of TV's connections at my mail.
rkr847@gmail.com
ramesh22
Jun 18, 2008 | Televison & Video
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Onkyo TX-SR502 Receiver Logo
141 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
