Question about Sport & Outdoor - Others
I have a proform 595 HR crosstainer and the resistance seems to be stuck and doessn't change when you press + or -. Also on setting 1 should it be really easy? Mine seems quite difficult even on this setting. Is there a problem?
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Half of my panel does note work it is proform 595
adjust the REED switch, test it for open or faulty. clean it, and plug it the terminal. see the diagram attached.
2) Tight the ribbon cable for keypads.
3) Replace the batteries by new ones FULL charges, with the same type, same polarity, clean the contacts batteries v.well
God bless you
Dec 06, 2012 | Proform 595 LT Treadmill
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 05, 2012 | Exercise & Fitness
Pro-Form 500 LE resistance is reversed
The problem I am encountering is that the resistance doesn't seem to change. Whether I am on 1, 5, or 10 it seems the same. Any ideas for ME?
Mar 14, 2012 | Exercise & Fitness
My Pro-Form 490 LE has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but it doesn't...
Open the rear part where the "guts" are. The magnet will be stuck against the wheel that turns when you pedal because the cable that the resistance motor pulls to remove the tension will have too much slack in it. The cable probably came off of the pulley wheel that is used to providing the necessary tension to pull the magnet off of the wheel.
To get the case off, simply unhook the right side pedal, remove the 4 bolts holding on the crank thing to remove it, then using a philips head screwdriver, remove the screws in the screw holes on the case cover. Be sure to remove the one screw on the other side near the front in order to allow the front part to "unsnap".
Jan 16, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Just bought my Proform 490 LE elliptical 1 day ago and it has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried...
Mar 13, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Sep 17, 2009 | Exercise & Fitness
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Change Tax Rate
I found this on the Casio site. I think yours is a printing model. If it is use the 2nd set of instrucitons. Hope it works...
Programming Tax Rate
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in “print” mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
Nov 27, 2007 | Casio HR-150TMPlus Calculator
Sport & Outdoor - Others Logo
53 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
