Question about Panasonic Home Theater System System
I have a panasonic SC-pt90 home theatre & cannot get sound from my Toshiba SL738B tv through my speakers. Connection is through a HDMI cable
    Brigadier General:
  • 8,546 Answers
Ideally, which way is sound traveling in an A/V scenario? I believe the best audio should always make its first stop at the Hi-Fi; and the best Video from each source should make its first (perhaps ONLY) stop at the TV/Monitor.
The TV-programming probably comes from a Cable- or Sat Box, which is itself an audio component with digital and analog outputs. Treat it like any other high-end audio source and run it straight to the SC-PT90.
The TV/monitor only NEEDS high-end video from everything and minimal viedo from the recever for management. Maybe analog audio from the cable box for watching the news.
Posted on Mar 27, 2011
Connecting a panasonic surround sound to a sanyo tv
if you have this option, use a hdmi cord from the dvd output to the input of the tv.most new tvs have several hdmi connectors. Then use a fiber optic cable from sound system to the audio input of the tv. between the both it should sound like a movie theatre. thats how i hooked mine up. good luck
Feb 27, 2012 | Panasonic Audio Players & Recorders
No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
May 17, 2009 | Panasonic AG-VP320 DVD Player/VCR
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Panasonic Home Theater System System Logo
484 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
