Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark CD MIX2 right deck skipping, sounding scratchy
Just purchased a brand new Numark CD MIX2 to replace my larger, bulkier set-up. I was really looking forward to the lighter rack. Unfortunately, the right deck continuously skips, gets stuck, or sounds scratchy when I play certain burned CD's. Those same CD's sound fine in the left deck. They also play fine on my home CD player. I've read this is a common problem with this particular model (a little too late, however). Any clues how I can get around this wothout having to pack it up and ship it back?
  • 1 more comment
  • Anonymous Mar 22, 2014
    I opened up mixer and cleaned the optical lens and checked for loose connections.when playing in stereo it only plays on one side but is still distorted.
    i opened and cleaned the optical lens and checked for any loose connections. getting low output and in stereo mode it only plays on one side.
  • Anonymous Mar 26, 2014
    sound not working
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Posted on Sep 27, 2008
My numark cd mix2 won't play a disc on the left hand side, it just says no disc
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
May 18, 2011 | Numark CD Mix2
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
My husband owns a numark ns7 and the music is scratchy sometimes. sometimes it is the left side and other times the right. he just bought a new cable, but that didn't seem to help. any thoughts?
Scratchiness from a CD might be audible evidence that the CD player is vainly trying to conceal errors. Are the discs commercial or consumer-created?
I've had this happen on a few CD's I've recorded myself and there is no way to determine why the data is marginal. In my case, I just chalk it up to bad media.
Feb 26, 2010 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark Axis 9's. . Problematic. Ahhhh!!!
Sorry, this isn't a solution but I just wanted to mention that I just got an Axis 9 and it is not playing burned CDs either. And I see another problem reported on this site specifically called "my axis 9 wont play burnt cds". What in the heck, Numark? Are all the Axis 9's this way?
Jan 18, 2010 | Nu Mark AXIS 9
HOW DO I HOOK UP AN IPOD TO A CD MIX2 , i hooked it into the aux on the back, i didnt get no sound evevrything was hooked up ,
You would need a Stereo jack to RCA cable. Input into Aux channel in rear, make sure your switch on faceplate is set to Aux. You may also need to turn up volume on the ipod.
Dec 07, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
Skipping cd deck 2 on numark cd mix 1 player.
paul asked my KAM KCD130 cd deck starts to slow down during playback
Jan 25, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Moodey newmark cd mix 2
Just wanted to tell you i have the same problem with my right deck! after about 2-3 hours of usage the right deck will start to skip while playing a cd...almost sounds like im fast forwarding then itll just stop playing, but only on the right deck! Ive noticed that it happens when the unit gets hot whether by usage or sunlight. Now as for youre issue about the crackling, i have two staements one is the cd youre playing scratched? ive had cds that have had minor path scratches that follow around the cd not straight across scratches..while playing this sounds like static or crackle then fades away! I would recommend playing the cd in a entirely different unit to see if this is the prob...if you know this is not the issue i would say that its a loose connection to a capicator or that a capacitor is on the way out...this happens when the capacitor is cold and doesnt let proper flow to go thru but as the capacitor heats up it it may heat the connection making a better contact.....just out of curiousity do you have the right rated fuse in the holder.. sometimes just having a fuse off by a couple of volts or milliamps can cause the same effect
Nov 12, 2007 | Nu Mark Numark CD-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
314 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
