Question about Hotpoint Washing Machines
Could you tell me what is f - 18 flashing on my hotpoint wt960 washer
  • 2,510 Answers
"F18" means a communication error. and this means that the PC board has failed, a wire or plug has come loose. It is electronic and needs experience so if you decide to investigate , look for bad connections, very carefully remove the pcb plugs making a note of exactly where each plug came from, clean contacts and replace.Look for obvious damage on the PCB's Replaced after doing a wipe over with a soft dry cloth. It is worth a trying it before paying out service call prices. Just make sure that the plugs are replaced in exactly the same position they were in!
Posted on Mar 27, 2011
How can I release chid lock on hotpoint ultima wt960
The Child Lock button is the second from the right in the line of buttons below the LCD screen. Press and hold this button for at least 2 seconds (or until you hear the beep and the icon light goes out). With a number of appliances, I've found that it takes longer than indicated to release a child lock so hold the button until you hear the beep.
The manual for the Ultima WT960 is available here: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf . See the bottom of page 18 for the child lock toggle information; the picture of the washer option buttons is on page 9. Use the Adobe Reader Zoom to see the keys (at step 5 of the Starting a typical wash programme). Other Hotpoint appliance manuals are available here: http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do .
If the lock will not release, then you may have a problem with the keypad or the controller.
I hope this helps.
May 10, 2012 | Hotpoint Washing Machines
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
My machine is flashing F-01 Hotpoint ultima WT960
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Jul 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Does wt960 have an eco mode?
This model does not have a specfic energy save programme, however, by selecting a coolwash at 30oC or a mini load, you will use less energy.
These features are detailed in the user instructions.
Plz rate my solution.
Thankyou.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WT960 is in the middle of a program and on the rinse cycle and on the screen is flashing H2O the door is locked with my wool wash inside. What do I do.
Check the program that you have it set on for the wool cycle. Some washers have where you can "add water" in the rinse cycle. If yours has this feature, I would try that also.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
187 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
