Question about Samsung Cell Phones
Bought the phone on thursday it charged up for its first charge ok battery run down so i conected the charger that came with the phone now it wont charge nothing wrong with the charger tried it on an lg phone no problem should i take the phone back
  • Samsung Master
  • 32,281 Answers
The battery most likely is faulty. You should be able to exchange under warranty.
Posted on Mar 27, 2011
I bought a new battery (FNB-RG-67LI) that arrived with 7.6 volts. I installed to the radio and conected to the ac outlet. After 12 hours charging is in 7.6 volts. my radio is the yeasu FT 60 with the...
That is about the nominal full-charge voltage on that battery pack. If the radio works, use it, let the battery run mostly down and recharge it. The FT-60 is a great radio, and mine shows between 7.4 and 7.8V with a fully charged battery, so yours is probably OK.
Sep 02, 2011 | Vertex Yaesu Radio FTH2070 Compatible...
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
New battery wont charge back up
there is a problem with your charger. dell chargers have a habit of blowing. there is a small chip in them that tells the computer that it is ok to charge the batery, that little "safety feature" blows out and will no longer charge your battery. you will have to buy a new charger, either at a store like best buy (make sure it specificly says it is compatible with dell) or go to the dell website to order an "official" one. both options are unfortunately a little expensive, but your only option. i had the same problem with my xps1330.
Jul 19, 2009 | Dell Latitude D500 Notebook
Samsung sj 600 just wont charge,
first thing to do my dear is try another charger if it wont charge it means the cellfon itself, if the celphone have the problem, change the BATTERY TERMINAL
Apr 03, 2009 | Samsung Cell Phones
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Sep 14, 2007 | Panasonic X700 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
