Question about HP Compaq nc6000 Notebook
HP Compaq nc6000 freeze
Originally when computer was turned on the blue light (far left) would come on and then the orange (third from left). After a few seconds, on battery OR adapter only, they would both go out, on battery & adapter the orange light would flicker and stay on The RAM,HDD,AC adapter plug,CD drive& RAM were all removed and re-seated. After doing this the computer would sometimes boot up and open Windows (XP) normally. This process was done powering from the battery alone, the adapter alone and with both connected. On some occasions after about 30 seconds the screen would freeze and the only operational key was the on/off button. On some occasions after about a minute Windows would close down and automatically restart, & go through the process again & again. Rarely would the computer operate for an hour. The fan is exhausting warm air from the back rear corner on each occasion. On two occasions after Windows shut down automatically, during the restart the following message occurred.
"A problem has been detected and windows has been shut down to prevent damage to your computer.
MACHINE_CHECK_EXCEPTION
If this is the first time you've seen this stop error screen restart your computer. If this screen appears again follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue,disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, pres F8 to select Advanced Startup Options,and then select Safe Mode.
Technical information:
### STOP: 0x0000009c (0x00000001, 0x8054D570, 0xF2000000, 0x00000175)
Beginning dump of physical memory.
Physical memory dump complete.
Contact .... etc"
There has been no new hardware or software installed.
  • arty36830 Dec 03, 2008
    notebook freezes up on safe mode sreen will not go any further must turn power off and restart with the same outcome every time
  • Anonymous Mar 12, 2014
    A DPC watchdog violation occurred. The computer updated it's software automatically and the watchdog violation didn't occur again. I realized that when I removed the charger the screen goes blank and when charger is on the laptop functions as normal.
The problem is with the mother board, there is a short near the fan. The machine is on its last legs.
Posted on Sep 25, 2008
Guys i have the same laptop and has been facing the same problem for sometime now.
The problem is with your VGA. I got it repaired couple of times and it started working again. But the guy who repaired told me to sell it as it wont last much. After about a month i started having same problem. First it used to stuck... then start working again. Later when it is running, screen would freeze and you can not do anything then to restart. And after sometime, it woud simply not boot. The lights would come on and off and nothing happen.
I do not know how they repair but im sure it isn't a big deal. They do this in just about half an hr. The problem is related to VGA, they kind of clean it. So if some of you know how to do this, please share.
Posted on Aug 13, 2010
    Problem Solver:
  • 10 Answers
Reseat everything again. Clean your fan with canned air.
Do a CHKDSK if there any problems with the hard disk. Do you have any of the startup CD that came with your laptop?
Posted on Aug 05, 2008
Hp nc6000 when pushing on , it will on orange light and off againg
1,check power supply.
2,check battery.
3,check the fan is trying to run.if its not it may need cleaning.
4,over heating can stop it from starting.
Jun 27, 2014 | HP Compaq nc6000 Notebook
My HP compaq nc6000 wont turn on, a orange light comes on at the front but wont power on, it doesnt have an internal battery only runs from main power supply.\r\n Please can someone tell me what the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 08, 2010 | HP Compaq nc6000 Notebook
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
Compaq nc6000 can not connect to my 2wire modem
wants internet sure.
2 wire, what is that? no modem model stated
no ISP stated, is this an old DIAL up? modem, 2 wire POT telephone land line , modem or DSL line, it too is 2 wires.
actually even cable is. 2 wires, center and shield.
NC6000
No OS stated windows what
NO ISP stated..
no connection stated, wired ethernet or wifi, or router,
tell more get more, please.
Dec 28, 2017 | HP Computers & Internet
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
Cambell problem
hey this is krista
okay so if you go allt he way down to your far far left you will see the button that says ctrl if you look 3 buttons over you will find the ALT button and if you go all the way to your way way upper right button then you will fing the DEL button if you hold all 3 of these buttons down at the same time and this will unlock your computer!
hope i helped, krista!!
Feb 07, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 won't come on
well make sure the battery is fully charged you could have a bad motherboard or no memeory inside it check those first
Nov 08, 2008 | HP Compaq nc6000 Notebook
Compaq nc6000
my nc6000have the same problem. if i press the keyboard when i turn it on it start but stop after 10 minutes !!!
Jul 05, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
2,040 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
