I have a BEKO wm5100w and it has started making an awful noise when draining. Its definately not the spinning, ust the draining. It also leaves the clothes with a funny smell. What could be the problem?
  • Washing Mach... Master
  • 1,527 Answers
Hello sound like there could be somethink stuck the in the pump like a coin or metal also check the filter if it has 1 and check the drain hose. hope it helps
regards
shaun
Posted on Mar 27, 2011
  • Chris Joel Mar 26, 2014
    Thank you Shaun, I had this problem too so went to open the filter and it would only turn 90 degrees. I guessed whatever was in there was blocking the filter from turning too. I turned the machine on its side and undid the telescopic rubber hose. Voila! a bra wire! Thanks again for the advice.
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Washer will not spin, it makes noise as if bearings have gone, empties ok and washes ok
Hi if your beko washing machine is causing a problem and wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
May 03, 2014 | Beko Washing Machines
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
How do I drain out the WM5100W
Turn the timer dial to any spin cycle selection and start the machine.
May 26, 2012 | Dishwashers
Hello, I have a beko wm5100w and it seems to be stuck trying to pump out water. I have cleared the filter and pipes, but now I need to reset the machine. I have done the "switch off, turn to 90...
It could be a faulty thermistor (showing high temperature)
or water sensor fault that is causing the pump to run.
Just try and unplug it for 3-4 hours, and see if it resets itself,
if not replace sensors, and if that does not work, replace the main board.
Here is the manual:
http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21
This is the actual reset/diagnostic mode
https://www.youtube.com/watch?v=8C4J3leArY0
https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
Sep 05, 2017 | Zanussi F1045W Front Load Washer
I have a beko wm5100w washing machine and it keeps tripping the electricity
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Nov 25, 2010 | Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Washing Machines Logo
420 people viewed this question
Top Washing Machines Experts
