Question about Gigabyte GA-945GZM-S2 Motherboard
What is plug of cd room - Gigabyte GA-945GZM-S2 Motherboard
    Guru:
  • 610 Answers
Are you asking which cable will you be using for the CD-ROM? Please give more details.
Posted on Mar 27, 2011
I have a Tivoli Music System radio/CD player. When it is moved to another room and plugged in at the new location, it won't run! The screen lights up a little, but has to sit for 30-40 minutes bef
The Tivoli Music System must be left without power for a minute (60 seconds or more) anytime it is unplugged, before being plugged in again. If you observe this little rule when changing rooms, it should turn on and be usable immediately (after ensuring it has been at least a minute since it was last connected to power.)
Nov 18, 2012 | Tivoli Digital AM/FM/CD Hi-Fi Music System...
How to eject cd
If you CD room drive will not eject CD with the use of his button, You use a pin you can see at your CD room drive a small hole use a pin to open your CD room drive. Insert a pin or neddle to the small hole and push. Your CD room will open.
Mar 02, 2010 | Dell Studio 17 Laptop
My cd drive isn't reading and discs and is not
hi,
there might be no connection from your cd-room slot.Pull out your cd-room and clean it, use a paint brush or a used toothbrush to get rid of the dust. After that, return your cd-room to its normal position. If still not working, replace a new cd-room.Hope this may help you.
best regards,
kaybicks
Feb 27, 2010 | Acer Aspire 5102WLMi PC Notebook
Hi guys my p.c wont boot! when I press the power on and press the front power button all the fans start running and the c/d rom starts trying to spin i.e the green light flashes 2 times every 5 sec's or...
Hi...
The problem that you have are same in common, if your cd room will not boot you need to first boot your cd room, you just go to the BIOS to first boot your cd room,, when you turn on the computer you need to press the delete key (or F2) after that, use the arrow key to select, chose the boot priorities, then you need to first boot your cd room, after the cd room first boot, press F10 to save, the ok
Good luck !!!
Regards
PCmania
Jul 09, 2009 | Gigabyte Computers & Internet
My cd and dvd drives are not working
check the Dvd or CD room.. the connection, reading lens,
or the cd room board
.. you try another cd/dvd room to check
thanks
Jun 02, 2009 | Computers & Internet
My computer Motherboard Asus P5QL Pro Intel core 2 duo cpu e8600 Hard disk seagate barracuda 7200.11 1TB 3.0 Gbit/s Video card XFX Geforce 280 GTX 1024mb DDR# XT i am trying to install windows
what is the problem? cannot install os? changer you cd installer, or check your cd room drive... if you meet problem for installation.. basic is, changer your cd, if fails, use another cd room if cd room som problem.. or maybe you need to turn dessable the sata in the bios..
Apr 14, 2009 | Computers & Internet
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
Gigabyte GA-945GZM-S2 Motherboard Logo
23 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
