Question about LG WM-2077C Front Load Washer
I have a LG WF-T1081TP i get error bE, abnormal ball sensor. can i fix it my self?
2 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: LG washing machine WF-T1031TP erra
light flashing means that there not sufficient water coming through the inlet.
Posted on Aug 04, 2008
I have a lg top loading machine model no. WF-T851 with a bE fault. What is this and how is it fixed.
There was a similar question that was resolved a few years back, perhaps it may help. Here is the link:
LG 3 turbodrum wf t851 bE error code
Jan 30, 2017 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Lg intellowasher wf-t1081tp hot water intake slow.
wich is connecting with inlet hose & inlet valve,,back of the machine,,thre is one filter in side the valve, remove &clean it,,pls
Apr 12, 2014 | LG Washing Machines
Wld like to re-set temperature for washing to 'cold' Can't find manual. Wld like to know how to change settings. It is a 'LG Intellowasher 3.3 cu ft top loading 3 Step Turbodrum WF-T1081TP' Thank you
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Jan 04, 2009 | Washing Machines
LG washing machine WF-T1031TP erra light flashing bE which i think means Abnormal ball sensor
Aug 04, 2008 | LG Washing Machines
LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Dec 19, 2006 | LG WFT1071TP Top Load Washer
LG WM-2077C Front Load Washer Logo
79 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
