Question about Chicco 4-in-1 Quattro Ride On Car
The steering wheel for the chicco 4 in one car is broken - not a battery problem, its like the on off switch has just locked so nothing works now. Can you buy a replacment - we live in Ireland
SOURCE: Broken Sun Shade on Red Chicco Capri
I have the same problem. I contacted Chicco customer services and they put me in touch with "Stork Talk" 0115 9306700 who proved replacement ones at 15 pounds including delivery, bit pricey I thought but I can't find any other provider!
Posted on May 12, 2008
MNfisherman
  • 11896 Answers
SOURCE: wheel replacement
You can buy them on Ebay for $8
or
you can contac chicco at 1-877-424-4226.
Posted on Jun 06, 2009
  • 5 Answers
SOURCE: Rear replacement wheels for Chicco 6WD stroller
try stork talk 01159306700
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: Need to buy one back roller (wheel) for chicco
check out their site: chiccousa.com and contact customer service. they should be able to help with parts.
Posted on Aug 18, 2009
SOURCE: Wheel lost off Chicco London Stroller
hi i have had the same problem and contacted Chicco, i was given the number for Stork Talk who can sell the wheels direct to you, £8.50 each, they were very helpful. Number is 0115 9306700 - www.storktalk.co.uk. Hope you get it sorted.
Posted on Dec 17, 2009
2002 2.2L engin 4 cylinder Pontiac grand am steering wheel don't lock after driving car. in park position and remove the keys. Steering wheel moves freely?? It's it the ignition switch going bad??
The ignition lock includes the steering wheel lock. It's possible that it just needs lubrication, or that the lock part has broken. In either case, taking the covers off the steering column sounds like your next move.
May 28, 2015 | 2002 Pontiac Grand Am
Lost power steering, car died, changed battery, and barley made it home. The battery has power, but when you turn the key on the dome light and other lights, radio, windows, etc don't work.
Sounds like the vehicle is not charging you may need a new alternator get the car going with jump leads again and test the voltage at the battery terminals with a DC volt meter expect 13.5-14.5 if you get less than 13.5 your alternator is bad or wiring fault also check the alternator belt is tight.
Apr 27, 2015 | 2005 Volvo S40
Push button start failure
possible switch in steering locking mech. try rocking steering wheel, see if you can get it to a point where you hear a click, and the steering wheel does lock
May 28, 2014 | 2009 Nissan Cube
While driving steering wheel locked up
Has it thrown or broken the belt?
When you say locked do you mean real hard to turn or the locking pin has engaged?
May 14, 2017 | Dodge Ram 1500 Cars & Trucks
Chicco trio scoop wheels
Hi Dessi
We'd recommend you speak with Chicco for assistance.
Chicco UK Contact Us Contact us
Mar 11, 2014 | Chicco Trio scoop morgana
Steering wheel stuck
if steering wheel lock with key in the ignition switch, more likely ignition switch keylock cylinder broken.or you are using wrong key.
Aug 26, 2012 | 1993 Nissan Sentra 4 Door
Steering wheel locked, and key will not turn
maybe the lock cylinder is broken?? do you have a ton of weight on your keyring? this can wear a lock very fast
Jun 23, 2017 | 2001 Chrysler Town & Country
What is problem when ignition switch wont turn or unlock
Try turnning steering wheel back and forth while turnning key.Sometimes they get in a bind if wheel is turnned against the lock.If this don't work,it could be in the steering collum or at engnition switch.
Feb 19, 2011 | 2003 Ford Focus
The ignition switch on my 2001 Crown Victoria is locked. This has happened once before but turning the steering wheel released it. This time the steering wheel also locked and the gear shift lever is also...
There is a switch on the brake pedal lever that ties all of those components together. Most likely switch was hit with driver foot and jarred loose or broken.
Idea was to prevent someone from starting car or moving car without the drivers foot on the brake. Often brake lights will not light up. Fix that part and everything will release.
Oct 15, 2017 | 2001 Ford Crown Victoria
Chicco 4-in-1 Quattro Ride On Car Logo
35 people viewed this question
Top Chicco Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chicco Toy Expert? Answer questions, earn points and help others
