Question about Kitchen Ranges
The engine "HUNTS" WHEN RUNNING
  • 2,510 Answers
I take it you are talking about a car engine. Hunting is usually a sign of an air leak in the intake manifold. Check that all the bolts are tight and that there are no leaking gaskets.
Posted on Mar 27, 2011
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
2013 Thunderbird storm, top end engine ticking noise at idle, a lot worse when hot, any ideas?
Valve adjustment needed if you are ticking. Then, change the oil. And by change the oil, I mean switch brands. I use Mobil 1 fully synthetic with a K&N filter. Never had a problem. I also recommend Castrol Syntec and stay away from Amsoil and Royal Purple.
Jan 10, 2015 | 2013 Triumph Thunderbird Storm ABS
How do i reset dell latitude d505 SERVICE TAG GX9VK1X-595B, EXPRESS SERVICE CODE 36840490053 password authentication system
The Dell Latitude D505 is a personal laptop computer with a 1.2 GHz processor and a 15-inch display. The system is equipped with a System Restore utility that reverts the hard drive back to its factory-configured state. Running the System Restore deletes any applications and data that have been installed by the user since the computer left the factory.
Skill level: Moderate
Other People Are Reading
(function(){function a(c){this.t={};this.tick=function(d,e,b){var f=b?b:(new Date).getTime();this.t[d]=[f,e]};this.tick("start",null,c)}var g=new a;window.jstiming={Timer:a,load:g};})();(function(){if(window.jstiming){window.jstiming.a={};window.jstiming.c=1;var e=function(b,a,f){var d=b.t[a],c=b.t.start;if(d&&(c''f))return d=b.t[a][0],c=void 0!=f?f:c[0],d-c};window.jstiming.report=function(b,a,f){var d="",c=document.getElementById("csi");if(c){var h;void 0!=window.jstiming._bfr?h=window.jstiming._bfr:(h=c.value,window.jstiming._bfr=h,c.value=1);if(h)return""}b.b&&(d+="&"+b.b);c=b.t;h=c.start;var q=[],n=[],g;for(g in c)if("start"!=g&&0!=g.indexOf("_")){var p=c[g][1];p?c[p]&&n.push(g+"."+e(b,g,c[p][0])):h&&q.push(g+"."+e(b,g))}delete c.start;if(a)for(var r in a)d+="&"+r+"="+a[r];b=[f?f:"http://csi.gstatic.com/csi","?v=3","&s="+(window.jstiming.sn''"pagead")+"&action=",b.name,n.length?"&it="+n.join(","):"","",d,"&rt=",q.join(",")].join("");a=new Image;var s=window.jstiming.c++;window.jstiming.a[s]=a;a.onload=a.onerror=function(){delete window.jstiming.a[s]};a.src=b;a=null;return b}};var k=window.google_prefetch''{},l=k.bdt''"-1",m=k.dt''"1416992702674",t=k.dtd''"-1",u=k.bpp''"-1",v=window.jstiming.load;function w(b,a){var f=parseInt(b,10);return 0=a''a>f)){v.tick("_t0",null,a);var d=w(l,a);d&&v.tick("bdt","_t0",d);(d=w(t,a))&&v.tick("req","_t0",d);var c=w(u,a);(c''d)&&v.tick("bpp","_t0",c''d);(a=w("-1",a))&&v.tick("redir","_t0",a);v.tick("fb","_t0",f);v.tick("e2e","_t0",e(v,"ol",0))}v.name=b''"";window.jstiming.report(v,{e:"3311888"})};window.tick=function(b,a){v.t[b]''v.tick(b,a)};})();(function(){var g=this,l=function(a,b){var c=a.split("."),d=g;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var e;c.length&&(e=c.shift());)c.length''void 0===b?d=d[e]?d[e]:d[e]={}:d[e]=b},m=function(a,b,c){return a.call.apply(a.bind,arguments)},n=function(a,b,c){if(!a)throw Error();if(2<span>computer<img id="itxthook0icon" src="http://images.intellitxt.com/ast/adTypes/lb_icon1.png" ></span></a>.</li><li>2<p>Press the "F8" key repeatedly as the system is starting up. Stop pressing the key when the "Advanced Boot <a href="http://www.ehow.co.uk/how_8478562_reset-laptop-back-factory-condition.html#"><span>Options<img id="itxthook1icon" src="http://images.intellitxt.com/ast/adTypes/icon1.png" ></span></a>" screen appears.</li><iframe>
  • 3 Click "Repair your computer." Click "Next."
  • 4 Click the icon next to "Factory Image Restore." Click "Next."
  • 5 Click the check box on the confirmation screen. Click "Next."
  • 6 Click "Finish" to restart the computer when the restore process is complete.
  • Nov 26, 2014 | Dell Computers & Internet
    Briggs and Stratton hunting and surging.
    How about a leak down test?? sounds like blow bye. is it consuming large amounts of engine oil???
    Apr 08, 2014 | Briggs & Stratton Garden
    Idle up down
    hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
    no year, stated. so cant help.
    but ill answer in the generic,
    1: the ECU (got a carb,? )
    the ecu controls idle speed at all times.
    if not , there is a problem (you)
    A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
    b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
    c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
    lean is gross power loss and opening throttle bogs the engine.
    so is double bad. ISC makes it worse,
    all this breaks down to 2 reasons.
    1: ISC bad. in some way (gummed up. or restricted inside)
    2: bad fueling or air leaks. vacuum leaks.
    try answers , the hot cold question and the 2 speeds, of the hunt.
    lowest rpm and highest of the hunted range of RPM.
    Nov 23, 2013 | Honda Civic Cars & Trucks
    What does "h" or "l" stand for on a carburator adjustment screw ?
    H is the high speed adjustment ( screw in to lean the mixture and increase the revs, screw out to richen and decrease revs ) I is the idle screw, this will adjust the tick over speed of the engine, you can also have a srew marked L this is to adjust the low speed running by leaning or richening the fuel mixture
    Jul 21, 2012 | Garden
    I wish to adjust the idle tickover speed a wee bit on a 2007 Ford Transit 2.2 Duratorq engine. It is currenlty ticking over at approx 800 rpm and is hunting at this rev. If I could raise it a wee as I do...
    First ensure that the throttle interior is really clean, a surface layer of grime can upset the ECU's ability to meter and govern the air entering the engine. If the throttle body interior is found to be really oily and dirty check on the idle air control valve and make sure that it too is cleaned up. Next put the ignition switch in position 2 (on, but no start) and depress the accelerator fully and release. If there is an issue with the throttle position sensor this procedure can help the ECU relocate the throttle plate position. Start the engine and if it is still hunting locate the air mass meter (AMM) on the air ducting immediately next to the air filter and disconnect the electrical connection. Does this remove the hunting aspect?... the rev speed might change but for the moment concentrate on the evenness of the tick-over. If the idle is even when the AMM is disconnected but hunts when connected then look at replacing your AMM. Try spraying the AMM with no residue electrical cleaning spray to see if this improves matters.
    Dec 02, 2010 | Ford Transit Connect Cars & Trucks
    1989 vt1100c motor oil to reduce engine ticking
    20W-50 is good for muffling sounds in the motor. Depending on the loudness the ticking could be caused by Exhaust gaskets (o-rings) from the head to the head pipe(ticking sound ((at idle))and popping or backfiring on deceleration). When automatic cam chain adjusters are going bad you get a clicking sound, or worse, hydraulic valve lifters (for zero tolerance) going bad. Lifters tend to be a loud clacking sound.
    Jul 28, 2010 | 1989 Honda VT 1100 C Shadow
    Briggs&Stratton 4.5hp seeking/hunting
    Did you replace the pump diaphragm and gasket between the carb and fuel tank? There is also a screen on the carb and a secondary pickup 'hole' on the fuel tank that needs to be cleaned between them too. You'll see that when you take the carb off the tank.
    May 17, 2009 | Parks Optical 13.5hp Briggs And Stratton...
    Stalling & hunting idle
    does throttle sensor check out correctly???
    Jun 10, 2008 | 1995 Volkswagen GTI
    Kitchen Ranges Logo
    129 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
