Question about Xerox Phaser 3100MFP/S Laser Printer
HSYNC ERROR in phaser 3100mfp - Xerox Phaser 3100MFP/S Laser Printer
nakshatraipu
  • 241 Answers
SOURCE: Hello, how to reset toner cartridge for xerox
Through Module we can resetted Xerox 3100 permanently.
www.nakshatraworld.com
Posted on Dec 31, 2009
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
  • 78 Answers
SOURCE: model - Xerox phaser 3100mfp - while installation
could be faulty fuser.or you could remove and re instal fuser
Posted on Nov 30, 2009
SOURCE: how I can delete all saved in memory
The service manual says:
"Before you start, set the 8 bit parameter installation configuration 1 to 1."
This means that you have to go and make the last bit of the Software Switch from 0 to 1.
'Soft-switch 1: Tuning the ringing tone and automatic printing (3100MFP/X)"
When you go there you discover instead of being
10000100, it is 00100001 which means that the first bit is the last in our case.
When I changed the 00100001 to 10100001, then it opened me the option of down, #, 8 and I erased the memory.
Then after I pressed the 8, the printer acted like rebooting and when I returned to make the Software switch 1 back to the former state I discovered that the Software switch 1 returned to the former state by itself.
Posted on Jun 14, 2010
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
I'm Getting the following massage " printer error" HSYNC on the xereo mfp 3100
Its related to the LASER UNIT! When I had the problem I had the front cover off so it wasn't hitting the laser interlock switch which is located in the slot in the sheet metal on the front of the machine when the front cover is not shut........... If that makes any sense.
Jun 04, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Tonar empty error for xerox phaser 3100 MFP pritner
You have to reset your printer through a hardware module which is permanent resetter. www.nakshatraworld.com 09713862555
Jan 22, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Carriege jam on xerox phaser 3100 mfp
please you clean your copier scaner and two side pest fuser oil or carriege sensor clean
Jul 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox 3100 mfp error code (HSYNC)
xerox phaser 3100 mfp error HSYNC
What can i do to solve ?
Nov 24, 2008 | Office Equipment & Supplies
Xerox Phaser 3100MFP/S Laser Printer Logo
736 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
