Depends on which tap you're turning ON. If it's cold water tap, it's probably a water line. If it's the hot water tap, it could also be a line. As heaters leak, whether the water tap is ON or NOT. Opening a tap valve doesn't cause the water heater to leak. The main question is, was the water heater's tank drained, before the Winter Freeze, when no one was using it? If it wasn't, there's a good chance the water heater will leak too
Hope this helps you solve the leaking water pipes problem. Please let me know Thanks.
3 red lights is the red ring of death, 4 means your AV cable is disconnected. If it freezes up though, you have a bad DVD player in it. I would send it back.
You can check out the articleatezinearticles.comhttp://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369formoreinformation on fixing freezing problem of your xbox 360
While the iPhone certainly isn’t the first mobile handset to suffer
from freezes, its functional breadth and the fact that many of its
users install unsupported third-party applications make the device,
generally, more freeze-prone.
settings can result in a reduction in or complete elimination of freezes:
Tap Settings on the home screen. Tap General. Tap Auto-Lock. Set to “Never.”
Tap Settings on the home screen. Tap Brightness. Turn Auto-Brightness off.
