Question about Philips 190SW
I have a philips190sw monitor which I can not switch off, it just says ( monitor controls locked ) Please help thank you
Emachine T3504 monitor controls locked out
The problem is not one easy... The IC with controls system is down... sorry but u must go to an expert to fix the bug! Rate me if this help's you Thanks!
Sep 14, 2009 | E-Machines eMachines Monitor E15T4
Osdlock on my computer desktop for 17'' monitor
You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
Monitor control lock
press 14second menu switch..then show unloked,and check 5volt regulater ic Lm7805..
Jan 20, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
OSD main
1. first changed the control panel micro switchs.
2. press the OSD switch 15 - 30 secunds.
Oct 08, 2008 | X-10 17 in. CRT Monitor with OSD Controls
Monitor
The OSD (on screen display) is a lock feature that locks out all access to the control functions. Basically you can use this feature to lock the access to the control functions once you have everything set the way you want it so no one will be able to adjust them without unlocking it. To learn more about this option you can review this lcd monitor manual to learn about the details that your monitor might have (this may or may not be a manual for your specific monitor, but I am using it so you will get an idea about the different features some monitors might have. Yours may or may not have all these features). I hope this helps answer your question. If you need further assistance, I will be more than happy to answer any of your questions or help you. Have a good day.
If you would please rate my help, I really would appreciate it. Thanks
Jul 07, 2008 | HP Compaq WF1907 Monitor
Control Lock Problem w/ my Samsung SyncMaster 551v (black) monitor
with other SyncMasters pressing the "menu" button for at least 5 seconds helps ...
Dec 23, 2007 | Gateway FPD2275W LCD Monitor
Control locked
try pressing the buttons (with your monitor turned off) if they have allowances for switching (if it is a push button then each should be pressed slightly and you should feel that it switches through!) if you pressed it and felt hard ( like something was stuck) then the buttons might have misalligned from the switches on the board. do not open your monitor unless you have electronic servicing experience. other causes might be the monitor's sync. processing IC. it could be defective.
Nov 15, 2007 | Samsung 793S 17" CRT Monitor
Samtron 56V monitor
Even i was also having the same problem. We can unlock the control lock by holding the menu button for 10-20 seconds.... But now my problem is the message "Controls locked/" appears continuously. Screen width also reduced. If anyone know the solution for this please help. thanks in advance.
Surya
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
107 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
