Question about Dell Latitude D600 Notebook
Dell Latitude Problems
Hello all, about 2 months ago I set my laptop open on my floor while I was out of the house. Well my mom let our puppy loose and it **** just a LITTLE bit of **** directly on the power button. Every couple of weeks I'm able to get the computer to fully turn on, but once it shut it down the same problem occurs. The Problem: On the right side of the computer, the light above the battery charging is on, when I take the battery out and unplug it, then put everything back in, all the lights turn on for a second, but then disappear and show only the battery light again. Is the computer fried? It's just weird to me that every once in awhile I can get the thing to finally turn on, I have no data lost when it finally does fire up. Can someone please tell me if they know the issue? TY
    Genius:
  • 2,028 Answers
Liquid, pee in your case, no matter how small, can cause an electrical short and fry motherboard components. I'm going to say that it has fried a component, and you'll want to have it checked out. Since the unit does start on occasion, then it's most likely going to be a replaceable component, probably the power switch circuit.
Posted on Aug 05, 2008
Dell Latitude D610 virus killed programs
You can get a Recovery CD for your model Dell laptop from the Dell WEB site. Use this link to the Dell WEB site.
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Nov 17, 2012 | Dell Computers & Internet
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
Dell e5400
Understand.
Agree, Mr_gauravin.
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-e5400_service%20manual_en-us.pdf
[ In case you cannot directly download the Service Manual in PDF file format, here is the Dell Support link,
http://www.dell.com/support/Manuals/us/en/19/Product/latitude-e5400
Click right on - Dell Latitude E5400 and E5500 Service Manual (1698KB) ]
1) Remove ALL power. Remove the AC adapter (Charger) and Battery.
2) Use an ESD wrist strap, and connect to a good ground source.
(Electro Static Discharge)
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
[I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray, (Unpainted), on the table you are working on, or use a large metal knickknack (Unpainted) ]
3) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
4) The wireless switch is composed of two spring metal flat strip contacts, inside a plastic housing. One flat spring steel strip is stationary.
The other spring steel flat strip slides over it, to make a contact. It slides over a 'bump', or protrusion, on the stationary flat strip.
The wireless button is attached to the movable strip.
Due to;
A) Poor design
B) Low quality materials
C) Accidental bumping of wireless switch button
,can make the wireless switch defective.
I have been searching to find the switch itself to no avail. Perhaps you can find one, or some other expert on here has a link to one.
(Suggest check 'Mom and Pop' computer stores, to see if they have one from a 'parts' laptop)
IF, one cannot be procured, then suggest you use a USB wireless adapter. Use it's wireless capabilities, which will bypass the wireless module in the laptop.
One example,
1) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265581&CatId=2704
IF you do find a wireless switch, in the Service Manual click on -
System Board. Follow the procedures down to -
Palm Rest.
(Palm Rest Cover)
This should gain you access to the switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 27, 2012 | Dell Latitude E5400 Notebook
Flashing purple/green screen dell latitude 6400
This is along shot but you may have picked up a virus a few months ago, do a full system scan, also download malwarebytes anti-malware and do a full scan, if nothing shows up consider a full windows operational install, I have found in some cases it fixes the video problem.
Jun 09, 2012 | Dell Latitude E6400 Notebook
How to restore my D620 to factory settings without a CD?
Hello there!
Well its impossible to restore any of todays laptops without their factory os dvd/cd. You could setup new operative system and make your laptop simmilar to what it was on factory settings, or you can search dell to send you that same cd/dvd on your post mail to your house.
I suggest you read http://www.dell.com/ and contact them in order to solve your problem. Hope i helped you! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Dell Latitude D620 Notebook
Keyboard issue with Dell lattitude E5400
may some dust particles within the keys otherwise change ur laptop
Jun 26, 2009 | Dell Latitude E5400 Laptop
Internet access just stopped working!
Open Device Manager and check to make sure that the Wireless Adapter is not disabled. The red X can be caused by that. If it has the red X on it, right click and choose 'enable'. That should take care of it. If it doesn't, please let me know and we can look a little deeper.
~ Spoem
Mar 23, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 8200 Battery
I assume that you have your charger plugged in as long as you use the laptop...
There are very minimal chances o the battery having been damaged, since the casing on the inspiron 8200 is quite sturdy.. i suggest you get the charge socket (the socket that leads to the main wall electricity outlet) from a qualified technician...
Feb 26, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Latitude D610 Default Factory Settings
You should be able to contact Dell support and they will send you the CD's for about $25.
May 22, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
61 people viewed this question
Alun Cox
