Question about Watches
My steel tag heuer formula 1 (2004) has rubber trim on either side of the casing this is perishing local tag dealer says there is nothing he can do i emailed tag and had no response
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
Posted on Oct 25, 2007
  • 10 Answers
SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Posted on Oct 10, 2009
SOURCE: formula 1 battery replacement
I did it myself.Very easy use battery #394 buy at Walmart $5 made in Germany. I bought special tool to open and close the
watch on ebay
Posted on Nov 21, 2009
  • 2501 Answers
SOURCE: Tag Heuer Formula 1 with alarm WAH111A.RWV3350
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual"
Posted on Feb 10, 2010
escapement
  • 2334 Answers
SOURCE: How to adjust the steel band on my Tag Heuer
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Were is the serial number on a tag heuer 1990's formula 1 chronograph model 571.513T
It is located on the right side of the Tag Heuer logo on the back of the watch. It is not as deeply engraved as the rest of the markings on the back, but rather is very lightly 'tapped' into the metal. 71e414e4-eb33-401b-8e97-f7f3c2c92292.jpg
Jan 17, 2013 | Watches
Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Do you sell the rubber parts for the tag heuer wah1112 (red)
This part is a seal against water and to be sure that it is correctly fitted and tested, the watch should be sent to a makers service center.
You can find the address of you nearest center by going to "csec.tagheuer.com/csec/index.lbl" where you will find a menu on the left, choose "customer service centers" where you will find all the info you need.
Mar 02, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
My alarm does not sound on my Tag Heuer Kirium F1?
Have you a copy of the manual?
If you have, then you will see that it can be turned off (last page), is this likely to be the case?
If you need a copy, go to their web site "tagheuer.com", select "watches", then "tag heuer formula 1", then "man", followed by "Tag Heuer F1 chronometer" and finally you will see on the right a menu, select "user manual".
This seems to be a generic manual that cover both the chronometer and alarm version of the watch.
If these are not the correct instructions for your watch, opposite the "user manual" menu is a search box, put your watch model in this and there should be a user manual with it.
If not look at a similar watch for a generic manual.
Jan 27, 2010 | Tag Heuer Kirium Formula 1 Chronograph...
I need a user manual for the Tag kirum Formula 1 watch
Go to the Tagheuer web site (www.tagheuer.com/)
Select "watches"
Select "Tag Heuer Formula 1"
Select "men"
Select "Tag heuer F1 chronometer"
On the right hand side of the screen you will a menu and the user manual is the last iten on the list.
Jan 03, 2010 | Tag Heuer Kirium (CL1212.BA0705)...
Tag Heuer Formula 1. I have set it and in 15 min
you can find a shop to repair<a href="http://warhammeronline.cheap-wow-accounts.com/" >cheap warhammer gold</a>
Dec 25, 2009 | Tag Heuer Formula One
Red rubber around watch faded
My experience with Tag Heuer is that if it is covered under warranty, they will fix it. If not - they will fix it at significant cost. My stainless steel Tag was repaired after water damage for over $300.
Alternatively, if the watch still works, sell it on eBay but be clear that it is sold as a used watch, and show a clear picture of the face of the watch so buyers can see the fading. Some buyers will not care. Use the money to buy a new watch.
Nov 25, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
I require a stainless steel bracelet watch band for a Tag Heuer professional 200 meter
u need to go to a store that carries tag. go to tags web site and find locate store. if they dont stock the bracelet they can order one in. might be pricy
Oct 06, 2009 | Tag Heuer Formula One
What are the two digital displays on the top of the Tag Kirum F! for??
Use this link and read the info:
http://www.google.com/imgres?imgurl=http://image.vialuxe.com/Newsimages/1965_LRG.jpg&imgrefurl=http://www.vialuxe.com/News/Tag-Heuer-Tag-Tag-Heuer-Watches-TAG-Heuer-Kirium-Formula-1-Watch/315,870&h=260&w=315&sz=20&tbnid=mdhtEFEWdkvSlM:&tbnh=97&tbnw=117&prev=/images%3Fq%3Dtag%2Bheuer%2Bkirium%2BF1&usg=__PEFomHqQ5EXL6ulbCMX7La4FbWQ=&ei=pMuBSsytA4KsjAfZ3LmECg&sa=X&oi=image_result&resnum=7&ct=image
All that is one link.
Rate me, please.
Aug 11, 2009 | Tag Heuer Kirium Formula 1 Chronograph...
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
