Question about Bebecar M City Stroller
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
    Scholar:
  • 91 Answers
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
Posted on Mar 29, 2011
When I slow down, why is there a noise coming from the rear tire as if something rolling in the wheel or tire?
If the wheel cover is detachable, there could be something trapped inside. Also, a puncture repair plug could be trapped inside the tire. A third possibility is that the noise is related to a rear brake problem
Oct 22, 2015 | 1998 Chevrolet Malibu
Hi have a bebecar travel city but dont know how to fold it down.help
To fold down a Tracker City, firstly make sure that the front wheels are locked into fixed, non-steering mode, and that the adjustable-height handle is in one of the middle positions.
Look at the twist-grip in the middle of the handle. Press the button and simultaneously twist the collar in the direction of the arrow. The chair should begin to close at this point.
Next, find the secondary lock device, which is operated by means of a lever/tab on one side of the handle. Pull this upwards, tilt the chair forwards and continue the closing action until it is fully closed.
Align the front wheel using your foot, if necessary, to prevent the rear wheel from hitting it. To store the chair, fold down the height-adjustable handle.
Don't forget to keep the pushchair well lubricated, preferably using a silicone spray.
Why not ask service@bebecar.co.uk for a user-guide for the Tracker City?
Nov 06, 2010 | Bebecar Tracker City U319 Stroller
Have a bebecar pram-pushchair and have lost one of the protectors from the wheel. The make is bebecar grand style the wheels are 11inches or nearly 28cm. They are in blue. Every time the wheel is knocked...
The wheels on a Bebecar Grand Style are held onto the axle by means of locking clips which are, in turn, covered by hub caps. If your wheel comes loose when knocked, it sounds as though the locking clip either isn't there, or isn't clipping onto the axle properly (which can be solved by cleaning/lubricating the clip, or replacing it).
To obtain new locking clips and/or hub caps, get in touch with service@bebecar.co.uk.
Jul 24, 2010 | Bebecar M City Stroller
Wheels for prams
Replacement front wheels are indeed available for the Racer ST stroller. You would need to identify whether you required air-filled (AT) wheels or solid-tyre (city) wheels. Either way, pop into you local Bebecar retailer, or contact service@bebecar.co.uk.
Jun 05, 2010 | Bebecar Racer ST Jogger
New tryers and wheels for a bebecar icon
You should call into your local Bebecar retailer to discuss your requirements. Retailers can be found here:
http://www.bebecar.co.uk/stockists/stockists.htm
Or you could send an e-mail to service@bebecar.co.uk You'll need to specify the type of wheel (i.e. solid tyre or air-filled tyre) and the colour.
May 14, 2010 | Baby Gear
Bebecar ip-op front wheel falls off, parts missing inside it and do not know where to get a new one local to wimbledon. there is a spindle with a washer one side which has fallen out and I think by looking...
The starlock could have broken which holds the axle in place. Contact the retailer you purchased the pushchair from or Bebecar direct on 01692 408807.
Feb 26, 2010 | Bebecar Baby Gear
Compatible parts for bebecar tracker city chassis
If you have a "TS" system. The letters "TS" will be inside a triangle on the side of the seat or chassis. You can also visit your local stockist or contact Bebecar direct on 01692 408807 for more info.
May 05, 2009 | Bebecar Tracker City U319 Stroller
Hard tyres needed
You can't use hard tyres on the Raider At+ as it has a different wheel design. You try a foam tyre filler that could solve this problem.
Jan 31, 2009 | Bebecar Raider AT Stroller
Bebecar M City Stroller Logo
111 people viewed this question
Top Bebecar Baby Gear Experts
john milligan
ray gallant
Tom Chichester
Are you a Bebecar Baby Gear Expert? Answer questions, earn points and help others
