Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Power is on, lock symbol appears in display panel of both upper & lower draws. On pressing lock button on either draw you hear a click however their is nothing else showing in the display panels & there is no response when pressing the power buttons or any of the other buttons. Every thing is completely dead. Is their a fuse or overload button?
    Brigadier General:
  • 3,513 Answers
Hi
If the key/ lock symbol is showing in the display, then it is possible you have the child lock on. Disable it by pressing the key/ lock button on the panel. Press and hold the "Lock" icon again until one beep is heard to release the lock.
If this doesn't work then it is likely the drawer has come off the rails and is not able to slide right back. You will need to open the drawer and slides and refit. Unless you are technically savy you will have to contact a technician.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 27, 2011
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
How do I rest the Service indicator for a 2005 CLK Cabriolet? None of the suggestions listed below worked for me.
First make sure all of the doors, hood, trunk, etc are closed.
Turn the key to position 1
Press system select button(lower left buttons on the steering wheel) that looks like sheets of paper until you see mileage reading or temperature displayed.
Press the brightness button on the lower left instrument cluster 3 times. You should hear a signal and see voltage on the display.
Turn the key to position 2
Press the lower scroll forward/back button(steering left arrows)). You should see "service indicator" on the screen
Press the Brightness button again once. You should see oil type on the screen.
Select the oil grade you used by pressing the + & - buttons on the upper right on the steering wheel.
Press the scroll forward/backward button to confirm. Confirm oil reset, press R(brightness button on lower left on cluster) for 3 seconds should appear on the display.
Service confirmed should appear on the display.
Press the upper forward/backward button & "service indicator" appears on the display.
Press the upper system select button(lower left steering wheel button on left) The display should go back to basic mileage or temperature.
If all else fails. I believe the shortcut I took as a tech was, turn the key to the first position, scroll until you see the temperature or mileage displayed. Turn the key off, push in the brightness button and HOLD it while turning the key to the 2nd position. You should see something like do you want to reset service? press R(brightness) button for 3 seconds and it should reset.
Good luck. The newer cars are worse.
Oct 10, 2013 | Mercedes-Benz CLK Cars & Trucks
Key showing on panel
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Mar 17, 2013 | Bosch Washing Machines
I have a double draw dishwasher . the child lock key comes up and the dishwasher does not start
The lock button activates/deactivates the Keylock or the Childlock functions. This button has either a key or a padlock icon. I believe that on this model it is a padlock
Keylock
The Keylock feature disables all the buttons on the control panel.
To activate, press and hold the button until you hear one beep (3 seconds). The symbol
appears in the electronic display when the Keylock feature is activated.
Childlock
The Childlock feature locks the drawer and disables all the buttons on the control panel.
To activate, press and hold the button until you hear two beeps (5 seconds). The symbol
appears in the electronic display when the Childlock feature is activated.
To cancel the Childlock feature, press and hold the button until you hear one beep and the
symbol disappears from the electronic display.
This information can also be found in your product's Use and Care manual. If yours has been misplaced you can download or print one from Fisher and Paykel's website. http://www.fisherpaykel.com/customercare/userguide/index.cfm
If this doesn't work... And I've seen these units do some odd things. Try unplugging it for about an hour (if plug is not under sink you can turn of the breaker that powers the unit). Then plug it back in and see if that works. These dishwasher like many modern day appliances have solid state microprocessors in them which sometimes need reset just like a computer.
Hope this helps.
May 17, 2011 | Fisher and Paykel 23 in. DD603H SS...
Lock Symbol staying on
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Sep 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Setting tha alarm
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
Dec 21, 2007 | Timex Expedition 40141 Wristwatch
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Aug 23, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
