Question about Siemens 24 in. SE55A560 Built-in Dishwasher
My diswasher will not drain, it has been fine up until a day ago, I have pulled the machine out and cant see anything out of the ordinary HELP
  • 2,510 Answers
Remove the bottom strainers plates and make sure that the pipe is not kinked and that there is nothing obstructing the outlet pipe, and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Posted on Mar 27, 2011
Whirlpool WFW9150WW01 will not drain
New drain pump impeller maybe?otherwise complete pump i think
Jan 10, 2014 | Whirlpool Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Loud Clicking, but everything is working
The inside of the washer is very simple if you know what you are doing as anything…open the back and run the unit on spin and see if anything came loose it sound as something came off and it making the sound during the spin…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 20, 2009 | Maytag HAV2360A Top Load Washer
I HANE A WHIRLPOOL FROUNT LOADER THAT KEEPS FLASHING A CODE F11
"f11" error will be a bad ccu(central control unit) replace and you should be good to go.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message f 09 and f 02
remove bottom panel..reach up from bottom to door lock area pull down on small tab hanging there door will release ..dip all the water out you can ..shop vac will help..remove the knob on front of pump have towels handy clean pump trap ck pump impeller for obstructions reassemble and ck if problem persists may be loose impeller on pump
Aug 27, 2008 | Kenmore 46462 Front Load Washer
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Siemens 24 in. SE55A560 Built-in Dishwasher Logo
283 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
