Question about HP Computers & Internet
Re-installing WindowsXP Home from CD. Goes well up to end installation then shows Login screen and I get "The specified domain neither does not exist or could not be contacted". There is no start button and I cannot find a way to boot in safe mode and login as administrator. The same whether I boot from CD or HDD. Thanks in advance
  • 1 more comment
  • dmor5773 Aug 04, 2008
    Computer is a Compaq Presario B2800 notebook. I do not think the HDD was a fresh format. It was given to me with the Windows Home edition and correct CD and COA key. When I turned it on it asked for the CD to be inserted to continue.
    Thank you proton77. I followed your suggestions and chose to do the fast format, then installed XP with success. I then connected to the internet OK. Next I must install AV protection and MSOffice to make the computer useful again.
    I am very pleased with the result and my skill set has increased.
  • dmor5773 Aug 05, 2008
    Not sure how I formally close the solution but please accept this comment as confirmation that the problem has been fixed.
    Thanks to you again.
  • HP Master
  • 1,183 Answers
Are you trying a fresh format reinstall or a repair ?
Thanks
Proton
Posted on Aug 04, 2008
  • 2 more comments
  • Mandeep  Singh
    Mandeep Singh Aug 04, 2008
    Could you also provide us with the name of manufacturer of your system.
    Thanks
    proton
  • Mandeep  Singh
    As described by you the problem is that the OS cd is not booting and its going directly to the OS . First Lets make the system boot from the cd . To do this follow steps below, to change the First Boot device to Cdrom
    Configuring the boot order
    The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps for modifying the boot order may vary depending on the model of the computer.
    NOTE: BIOS configurations vary depending on the computer. For further information on a specific computer, refer to the documentation provided with the computer or go to the HP Drivers and Downloads page . The BIOS settings are generally listed in the Maintenance and Service Guide.
    Follow the steps below to configure the boot order on most computers.
    Turn on or restart the computer.
    While the display is blank, press the f10 key to enter the BIOS settings menu.
    NOTE: The BIOS settings menu is accessible by pressing the f2 or the f6 key on some computers.
    Select the Advanced tab using the right and left arrow keys.
    Use the up and down arrow keys to select Boot Order .
    Follow the on-screen instructions to change the boot order.
    Thanks
    Proton
  • Mandeep  Singh
    Resetting the defaults of the system properties
    Reset the boot order to the default settings
    To reset the boot order to the default settings, follow the steps below.
    1. Turn on or restart the computer.
    2. While the display is blank, press the f10 key to enter the BIOS settings menu.
    3. Press the f9 key to reset the BIOS to the default settings.
    4. Press the f10 key to save the changes and exit the BIOS settings menu.
    Thanks
    Proton
  • Mandeep  Singh
    Request You kindly Rate the Solution as Fixya. So that we can close the case .
    Best of luck for the future
    Proton
I forget my login password for my microsoft windowsXP proffessional
If you want to reset your windows password then i'll suggest you to download Hiren's Bootable CD. It contain a freeware application which can reset or remove windows password.
Google and Download Hiren's Bootable CD
Aug 08, 2012 | Gateway Computers & Internet
PC won't boot
Have you tried reformatting on the broken machine?
Oct 22, 2007 | Dell Dimension 8100 PC Desktop
Tip
How to format and instal a window xp
1.Insert your Windows XP installation disc into your CD drive<br /><br />2.Now as you computer boots a little more it will say "Press any key to boot from CD.." press a key to do so.<br /><br />3.The CD will load up a blue screen and then spend a while loading files it needs. When it is finished it will list a few options, mainly "Press ENTER to set up Windows XP." Press Enter or Return.<br /><br />4. Now you will be at a screen to select where to install Windows to. This is where you can delete old partitions and format drives. The box in the bottom half of the screen shows all your drives and the partitions that exist on them. Use the Up and Down arrow keys to highlight your "C:" partition and press the 'D' key (if all that shows up is "Unpartitioned space" and you have no C: or D: partitions, skip this step). On the next screen press the 'L' key to finalize deleting the partition.<br /><br />5.Now you are back on the screen to choose where to install Windows. The box on the lower half of the screen should no longer show a partition but simply have an entry "Unpartitioned space xxxxxMB." Select this with the arrow keys and press the 'C' key to create a partition on the drive. The next screen tells you the minimum and maximum sizes the partition can be and lets you pick the size. The default size is the maximum, but double check that the number entered is the maximum and hit enter.<br /><br />6.Now you will again be back at the choose where to install Windows screen. But this time you will have a partition that looks something like this "C: Partition1 [New (Raw)]xxxxxxMB." Highlight this entry and press enter.<br /><br />7.The next screen lets you choose which file system to format the drive with. Choose NTFS as it is faster and more secure. If the drive is brand new and has never been used before then use one of the options that ends in "(Quick)." Or, choose one of the lower down options. Use the arrow keys to select the proper one and press Enter or Return.<br /><br />8. From here you are all set and the installation of Windows will proceed starting with a format of your drive. This will take a while (over half an hour)
on Jun 23, 2011 | Computers & Internet
Tip
How do I recover a lost password for Windows
<p><b><span>Question 1:</SPAN></B><br> <p><b><span> </SPAN></B><br> <p><span>hello everyone .My niece recently bought a new laptop, and she decided to use a password to log on, but now she has forgotten her password and she cannot log on. Is there anyway to work around this or do we have to have it formatted.</SPAN><br> <p><span>thanks in advance.</SPAN><br> <p><span>From Computing.net by hulkster</SPAN><br> <p><b><span> </SPAN></B><br> <p><span> </SPAN><br> <p><span>Most of us are usually confronted with this problem-forget our Windows password and have no idea what to do. Now,let's get acquainted with this issue.</SPAN><br> <p><span> </SPAN><br> <p><b><span>1st Method: </SPAN></B><br> <p><span>The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:</SPAN><br> <p><span> </SPAN><br> <p><span>Start system and when you see Windows Welcome screen / Login screen, press "ctrl"+"alt"+"del" keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.</SPAN><br> <p><span> </SPAN><br> <p><span>Now you can reset your account password from "Control Panel -&gt; User Accounts".</SPAN><br> <p><span> </SPAN><br> <p><span>Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.</SPAN><br> <p><span> </SPAN><br> <p><b><span>2nd Method: </SPAN></B><br> <p><b><span> </SPAN></B><br> <p><span>Windows XP and further versions also provide another method to recover forgotten password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:</SPAN><br> <p><span> </SPAN><br> <p><span><a href="http://www.blog.lostwindowspassword.com/things-about-windows-password-reset-disk/">How to create and use a password reset disk for a computer in Windows</A></SPAN><br> <p><span> </SPAN><b><span> </SPAN></B><br> <p><span>If all fails,Simply go to <b><a href="http://www.lostwindowspassword.com/">Windows Password Key</A></B> website to download this tool,it can help you 100% recover your lost password.</SPAN><br> <p><span> </SPAN><br> <p><b><span>Windows Password Key 8.0</SPAN></b><span> is considered as the best tool to reset local administrator and user passwords on any Windows system. It creates a password recovery CD/DVD, USB Flash Drive for home, business and enterprise. And most of all, it's the most popular and safe solution for resetting your Windows password until now.</SPAN><br> <p><b><span> </SPAN></B><br> <p><b><span>How to use:</SPAN></B><br> <p><span> </SPAN><br> <p><span>(1). Login to a computer that can link to Internet. Download windows Password key and install it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.</SPAN><br> <p><span> </SPAN><br> <p><span>(2). Insert the newly created CD/USB drive to the locked computer.</SPAN><br> <p><span> </SPAN><br> <p><span>(3). Reboot the locked computer and press'F2'or'Delete
on Dec 03, 2010 | Computers & Internet
Forgotten log in password
Which system do you use?
On windows xp, try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
If that doesn't or you use windows 7 or vista, try this:
1. Enter a computer that can link to Internet. Download Windows Password Recovery Tool 3.0 and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
Resource: http://www.windowspasswordsrecovery.com
Aug 04, 2012 | Computers & Internet
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
XP PROBLEMS
At the windows login screen there should be a link or button you can click on and enter your key. Sounds like the person that fixed it didn't validate it. Did you install new hardware? If so, you'll probably have to call microsoft to validate.
Jan 18, 2008 | Gateway GT4022 PC Desktop
Video driver loading problem after clean XP home install
Are you sure that you are installing the proper driver, I mean are u installing the driver for windows xp? If you are not able to install in the proper manner. Do like this Right Click on My Computer>Manage>Device Manager>Display Adapters. If an yellow exclamation mark is shown then it means that you have not installed the driver and if its not showing any confilct (yellow exclamation mark)then you have already intalled the driver and your video card is also working perfectly. And the problem could be something else. If confilct(yellow exclamation mark) exits.. Do like this. Right Click on the exclamation mark>Update driver>Not at this time> Install from a specified location>make sure u have checked "search removable media..." and make sure that u have put the driver cd in the cdrom and click next. If you have put the correct CD then windows will automatically install the driver for your laptop. During the installation if system shows a message "This driver is not digitally signed..." Click continue anyway. If none of the above things work. Download the latest drivers from the net. -ShaC
Jul 26, 2007 | Sony VAIO PCV-W20 PC Desktop
Computers & Internet Logo
41 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
