It doesn't work. It shows LE or IE problems. What are they?
  • 2,510 Answers
You don not mention the machine. On a Samsung it would be a pressure switch malfunction. locate the switch and check that the pipe is clear and that the switch responds to pressure by blowing lightly into the pipe. This is what the switch looks like:-
It doesn't work. It shows - images?q=tbn:and9gcsewicujk9ns4e2jmdmppcyih_gqnxonjw5vn2kl0rartgsbb2l
Posted on Mar 27, 2011
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Jul 30, 2014 | LG LDF6810ST Stainless Steel Built-in...
Stops and shows flashinng OE when I open door clothes are sitting in water
IE: Water level (246) was not reahed in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermister out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2011 | Washing Machines
Dont know from where to download drivers for amd-athlon LE 1640 to run newly installed window 7 propely
"amd-athlon LE 1640" is only your CPU ie the processor for the Mainboard of the PC. The CPU do not need any drivers. To get the needed drivers you have to make know the Mainboard info ie Type/Brand/Name.
Oct 27, 2010 | Computers & Internet
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
Jan 25, 2010 | LG WM1814CW Front Load Washer
Error LE
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Nov 17, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does it mean when the washer LED reads LE? It is not working and LE is all that shows up.
Le is potential motor problem.I would reset the machine by unplugging for a couple of hours
Nov 10, 2009 | LG WM2688HWM TROMM SteamWasher
The panel has a LE ERROR.
LE is an ie .. water inlet problem. ... manual says to check for clogged, kinked, or frozen water inlet hose. check water supply.
OE. Drainage problem
FE excessive water supplied
E1 water leakage problem
HE heater circuit failure
TE thermistor failure, or very high inlet water temp
PF. power failure.
Jun 05, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
