Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
Have had my system running smooth as for about 3 years, running a p5n32e-sli. Running 2 8800 gts and matchest crossair ram. Have had no issues at all with this system and have made no changes. Today i go to turn and nothing. No boot, No post, No fans. All i get is a flashing LED by the PCI slots. Any help on this would be awesome Thanks David
    Novelist:
  • 107 Answers
Try to re-seat all of your connections. Un-plug the RAM, video cards, and PCI cards, then re-seat them back in their slots. It could have just been a loose stick of RAM had come partially out over the years of vibrations which would cause an issue like this.
However no fans gives me the idea that there may be something wrong with your power supply, or motherboard. Check to make sure that none of the capacitors on the board are puffing out, and if you have a spare power supply try hooking up only the necessary connections after checking the previous suggestions.
The problem with issues such as this are that so many different things could cause something such as this, so hopefully this helps!
Posted on Mar 27, 2011
Had my computer running for over 3 years smoothly but then i was getting blue screen and next day it doesn't even start to bios. I have motherboard M4n98TD Evo. I have tried changing rams and placing them...
i need to i looked at most of the books i have and they all basically say the same thing:
faulty video configuration (no or bad video card installed) or bad rom on the peripheral controller card address range c0000 through ffff
______________IMPORTANT__________________
CHECK CMOS BATTERY OR REPLACE FIRST AND REBOOT
BEFORE DOING THE INFORMATION ABOVE
TANK YOU ROD
Mar 02, 2015 | ASUS M4N98TD Socket AM3 Nforce 980a SLI...
Can i add 2 graphics card in asus P5G41C-M LX ? now i have nvidia GTS 450 graphics card.. plz help.....
Hello there,
*********** board has an Integrated Intel GMA X4500 graphics, maximum shared memory of 1G, it should be automatically disabled if the pcie slot detects a video card but some mother board embedded gpu runs with the pcie card unless disabled in the bios.
Do you have plans on running a SLI (Scalable Link Interface) linking two or more gpu to produce a single output on *********** board. why SLI? because you already hae a GTS 450 GPU but you cant do this configuration because *********** board has a single pcie slot.
If you have plans on running a pci gpu with your GTS 450 it should, but if you encounter any problem try manually assigning IRQ's and resources through the BIOS? I don't have this specific board.
Hopefully this information helps.
Thanks you for using FixYa.
Sep 18, 2011 | Computers & Internet
Last night my audio started cutting out when i played video files on any player ( vlc, media player) and this morning there was no sound at all so tried downloadingnew soundmax drivers and still had the...
It sounds like the on-board audio is dying, you could replace the motherboard but it is not necessary. You can pick up an internal sound card for around $20-$30, here is an example of the kind you would want.
http://www.amazon.com/Creative-Labs-SB0570L4-Blaster-Audigy/dp/B000LP0R3E/ref=sr_1_16?s=electronics&ie=UTF8&qid=1298949310&sr=1-16
Because they are so cheap and easy to install, i would say this is the solution that will save you the most time and frustration if you're willing to spend a little cash.
Mar 01, 2011 | ASUS M2N-SLI Deluxe Motherboard
Jetway motherboard 939 GT4-SLI-G will only accept 3.5 gig RAM and not 4 gig RAM as per specifications. It does not run on gaming applications when 4 gig inserted (4 x 1 gig). Any solution?
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
Jan 18, 2011 | Jetway 939GT4-SLI-G Motherboard
I am running a core two duo [2.4 ghz] with 2 gigs of ram [two one gig sticks] and was running dual 8800 gts vid cards [now running one] power suply is a 600 w Antec..MB is a p5n32-e Sli Asus, Ok heres the...
CK ALL YOUR DVD CABLES AND BE SURE THEY ARE IN TIGHT, ALSO CK THE MB PLUGS ARE IN TIGHT AND POWER PLUG IN IS DVD PLAYER CORRECTLY. DID YOU INSTALL THE SOFTWARE THAT CAME WITH DVD PLAYER??? IF SO, DELETE IT AND REINSTALL. SOMETIMES THAT IS ALL IT TAKES.
Nov 20, 2009 | ASUS AI Lifestyle P5N32-E SLI...
DISPLAY DRIVERS FOR VISTA
YOU CAN GET DISPLAY DRIVERS FROM THE MAKER OF YOUR VIDEO CARD.
ATI OR NVIDIA?
ATI GOTO http://ati.amd.com/support/driver.html
NVIDIA GOTO http://www.nvidia.com/Download/index.aspx?lang=en-us
OTHER P5N32E-SLI DRIVERS ARE AVAILABLE AT ASUS WEBSITE
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-E%20SLI
Oct 19, 2008 | ASUS P5N-E SLI Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Video cards pci-e
Hi s _beukelman7, one of the most important spec's of running two SLI cards is they must be identical. Your trying to run a 8800 & a 7300. They are both NVIDIA **** they are not the same. They are different & will fail in your system. Pg. 6-2 in your mnual. Either buy another 8800 or another 7300 SLI card.
It is suggested you go to NVIDIA web site & allow NVIDIA to check both your two graphic cards & system for the latest drivers. If NVIDIA finds you need updated chipset drivers please (follow all instructions) or your will find yourself re-installing your OS.
The two most important item you need other than checking the above link, is the correct power supply. Your manual suggest a minimal of 500w psu when using a single SLI card. I suggest running a 550w for dual cards.
The second item concerns the SLI cable. It must be clean.
Mike
Apr 01, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
