Question about Microsoft Xbox 360 Console
I have one red light lit up thesystem is saying error call xbox com sopport
    Problem Solver:
  • 10 Answers
Bakit ako my cross fire kayu wla
Posted on Mar 27, 2011
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Red light comes on the console
that's bad mine did that once what you need to do is take it back to game and they will replace it if you have insurance or call Microsoft by using www.microsoft.com and say that you have red lights you either have three red lights or one that says error code E74 and they will fix it if you post your xbox to them.
May 20, 2010 | Microsoft Xbox 360 Console
System error wen i pluged my xbox in red light is showing on start button screen says system error contact xbox customer support
this is known as the red ring of death,no worries it can be fix .becouse xbox get hot it courses the cpu to lose contact on 1 of its corners.
this link is to my usendit account its the step by step to repairing the red light error.there are 2 ebooks inside .its will be there for 7 days or 100 downloads . https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
Feb 26, 2010 | Microsoft Xbox Console
Three red lights on start up button xbox360
i think the three red light are over heating problems, if your console is un opened i think Microsoft are fixing them for free or you could find a repair shop and they could do the xclamp fix but Microsoft is the best bet.
hope this helps.
Aug 26, 2009 | Microsoft Xbox® 360 Core System Console
One Red Light in cpntroller number 4
Steve, what error code are you getting? Go here and find out what your error code means. http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Nov 23, 2008 | Microsoft Xbox 360 Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Technical support
Sorry to have to say it but your xbox is completely borken and will most likely need to go in for repair.
Mar 23, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
