Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a Fischer and Paykel Intuitive IW709AU washing machine and the bearings in the bottom of the tub are very noisey but not leaking yet. Are they difficult to replace?
  • dentext Mar 28, 2011
    Thanks for the help, it has explained exactly what I needed to know.
  • 1,998 Answers
Its about a 4-6 hour job in which you have to take both tubs out and seperate the inner from the outter tub and pound out the seated bearing usually techs charge in between 450-600 on this job parts will run you around 100 its a very time consuming job due to just about everything on the inside of the unit ends up coming out and you also would have to replace the main seal when you replace the bearing as well If you have any further questions message me back And please remember when our chat has fully concluded to rank how this opinion has helped Thanks Rick
it would be 4-6 hours if you did the job compared to 2-3 if one of them did
Posted on Mar 27, 2011
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
Oct 18, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher Paykel IW709AU wahing machine, it does not drain the water after the washing cycle ends, but a buzzing sound starts from the water pump for about 30 seconds and the power cuts out. the...
If you wired the pump directly with a lead and 230V supply and it works ok, then doesn't work when powered by the control board, I would say that there is a problem with the control board not supplying a full 230V to the pump.
Dec 04, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Hi our F&P iw810 washing machine makes a loud squeeling noise at the start of the wash cycle. What is it? (no belts or gearbox)
sounds like tub bearing or stator is cracked it also can be the clutch between the two tubs check for any hoses or wires touching the rotor its worth fixing as its a very goog model you have
Aug 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel intuitive eco
lean it back against the wall pump twist locks into bottom of tub..or pull the small plugs under each side of lid and remove the 2 phillips screws top lifts up
Jun 03, 2008 | Fisher Paykel Eco IWL16
Washing Machines Logo
259 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
