Question about Honda Electrical Supplies
I have a honda eu6500is generator and it doesnt charge its battery no more. Ive tried putting in a new one but it just kills it and is un able to keep it charged. It goes dead after a months use since it doesnt charge itself. If anyone can help please do
FixMySadMac
  • 10 Answers
SOURCE: my iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Posted on Oct 15, 2007
SOURCE: not able to charge battery
This happened to me also. In the manual it says the flashing light means that the battery/charger needs to be cleaned, or if that doesn't work, it is dead. My husband called customer service and they actually sent us a new battery which we recieved within a few days. The number is 1 800 706 2534.
Posted on Feb 03, 2008
  • 226 Answers
SOURCE: The battery doesn't stay charged in Guardian 10K
I think that is the problem as well. Temporarily, you could just buy a tricke charger from the parts house and hook that up until your other one is changed. Rick
Posted on Apr 13, 2009
  • 420 Answers
SOURCE: 2002 honda silver wing has been sitting for a
Is the motor turning over? If not you need to get the battery load tested. If you used a regual automotive charger on a motorcycle battery you might have fried the battery since the car battery will take more amps than the motorcycle batter.
Posted on Apr 19, 2009
amihasib11
  • 99 Answers
SOURCE: Sp Dead Battery
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
a-56
Posted on Jul 23, 2009
What is the gap between the module and flywheel on a eu6500is Honda generator
I don't know.
The air gap isn't usually critical. It needs to be a small gap for best efficiency but must not be so close it will touch if expansion brings it closer at operating temperature.
The last air gap I adjusted was on a Briggs engine and that was 0.008", 8 thou which I believe is fairly typical for that type of application.
Nov 09, 2017 | Honda Electrical Supplies
My honda generator eu6500is is flooding out.
Alfred,
Try checking the float 1st. Much like it is done in this video (different generator but same princible.):
Dec 19, 2016 | Honda Electrical Supplies
What controlls the rpm on a eu6500is
The inverter signals the throttle motor, which is really just a small servo motor on the top of the carb. When the inverter senses more load, it increases the throttle to compensate.
Jul 10, 2015 | Honda EU6500iS Inverter Generator
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
Where can I buy a hard copy owners manual Honda generator eu6500is?
The manufacturer would be an excellent place to start... and they have superb paper manuals.
Jul 31, 2014 | Honda EU6500iS Inverter Generator
1995 VF750. The bike will start after i take off of the trickle charger. Idled for about 20 min then died and won't start. Put back on the trickle for a couple minutes and it started again. I think the...
It has either a generator or alternator style system. So ya your killing the battery and need to stop that till you fix the generator charging system. Check the fuses and wires for any breaks. May need a new stator or charging controller if the fuses are not the problem. May be even a bad ground wire.
Jan 02, 2018 | 1995 Honda VF 750 C Magna
Honda generator 6500
first always check the spark gap and maby replace the spark plug just to get this possibility out of the way, if is hard to start it could because it is not getting enough fuel to start COLD or it is getting to much fuel, smell the exhaust for the tell tail signs of un-burnt fuel a good way to check is to have a friend hold a rag over the intake of the carb wile cranking, if it lights up then your not getting enough fuel, maby replace the carborator, also try a snifter of eather/ cold start if it lights right away your not getting enough fuel
these are some suggestions, you can also check compression if the compression is to low it will be hard to ignight the recommended fuel charge but run OK when warm
Best wishes Falco
Nov 03, 2013 | Honda EU6500iS Inverter Generator
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
Jan 24, 2012 | Honda Electrical Supplies
Electrical Supplies Logo
656 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
