Question about Canon PowerShot SD1000 Digital Camera
Water damage - worth repair?
Okay so a small amount of water (half a teaspoon at most) was splashed into my open shutter of my sd1000 elph. It would not retract the lense, adn the lcd started showing static and white flashes. I took the battery out, and let it sit for a day. I put the battery back in and it started popping like it was short circuiting. Canon has it now and says it is corrosion and liquid damage. Is my poor camera now just to be used for parts or is it salvageable by Toothy Sam or someone like him?
  • J12321 Aug 04, 2008
    Thanks for your response, Jig. I saw parts of it for sale, like the LCD, the battery cover etc on ebay. So, atleast the non electronic parts can be sold for parts, right? How much should a broken sd1000 fetch on ebay?
    Master:
    Sergeant:
  • 398 Answers
These are electronic devices, and have NO tolerance for moisture inside. The popping sound you heard tells the story. I suspect that you have lost this unit.
Posted on Aug 04, 2008
SOURCE:
How do I clean each of the water dispenser on model 3010 hamilton beach
You can use white vinigar or baking soda. I use baking soda because vinigar will dry out the seals over time. If you use baking soda, mix a teaspoon full in a small amount of water to break it up, fill the unit half full of water, add the mix, fill the unit with water and run the unit as normal. If you use vinigar, add one teaspoon to a full load of water and run the unit as normal. When the cycle is finished, fill the unit with plain water and run again to flush.
Hope this helps.
Oct 22, 2014 | Coffee Makers & Espresso Machines
My Canon SD1000 screen has gone blank.
First press the DISP button to make sure that you didn't just accidentally turn it off. Next, a stuck shutter is another common failure mode for digital cameras (very common for the SD1000 by the way, but also very easy to fix). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 16, 2011 | Canon PowerShot SD1000 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1100 IS Digital Elph
there are some settings that can help with this (check out red eye and flash settings). The best solution I have found is to press the button down half way. The view finder will try to frame the picture, and then press the button all the way down. This 1) Eliminates Red Eye 2) Increases picture speed 3) allows for the "perfect" moment because you can leave it at half pressed for as long as you like, and 4) Allows you to take rapid fire pictures if you don't depress all the way.
Hope that helps
Oct 24, 2008 | Canon PowerShot SD1000 Digital Camera
Canon powershot SD1000 digital
your question make no sense obivously your water in your camera please put a better question so i can help
Jun 28, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
SD1000 _ Wont turn on and I'm on vacation!! WHY!!!
Withe the PowerShot Digital Elph cameras there is unfortunately very little that you can do for a power problem besides determining that either the rechargeable Lithium ion battery or the battery charger itself is not the problem.
Of course a good battery will work fine in another similar camera. Usually the charger works OK if the lighting sequence on the charger goes from Red to Green on a low battery within a 2 hour period of time (it should also alternate between red and green when the battery is approximately 90% charged).
If the battery and the charger are in good working order then the camera likely has experienced an electrical communications error within the power circuitry which, more often than not, is due to some sort of impact damage. Often users don't realize that their cameras have experienced impact damage but these cameras are unfortunately very fragile. A fall of as little as two feet can do sufficient damage to require service.
Given the scant amount of surface area that the contact plates actually have with the camera body, cleaning these areas will rarely effect a solution and resets cannot be performed on cameras with no power, so the result, unfortunately, is that the cameras will typically have to be serviced.
Hope this helps.
Sincerely,
HeavyDLB
Mar 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD1000 Digital Camera Logo
258 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
