I purchased this unit approxiamately 2 and a half years ago. I was not using the unit when I smelt something burning, I traced the smell to my dvd micro system and found that it had caught alight, I ripped out the power to prevent damage to my property. I checked inside the device and I have found that the fuse is still intact and the board caught alight. Thank goodness I was home when this happened.
    Brigadier General:
  • 8,546 Answers
And your question is where to bury the carcass, since that is what it is.
Take it to hands-on specialist for forensics before applying power to it again. Only then will you have an idea of the extent and expense of the damage.
Posted on Mar 27, 2011
Dryer smelled like smoke and hose filled with water
Something is plugged dryers vaporize wetness not create water
make sure all ventilation is clear
Apr 02, 2014 | Samsung Dryers
My rainbow 1650- was working fine then all of a sudden it powered down and had a burning smelt a little electrical, but also like something else. Then I hit power switch andi unplugged The unit. I took...
It might have been the wad passing through but with a burning electrical smell it should be checked out by qualified technician. Burning electrical smell means it may catch on fire
Sep 23, 2013 | Vacuums
I have a 97 bonnaville. While the car is running, all the lights flicker and the engine surges in sync with the lights. I have also smelt something burning but the smell only lasts a few seconds. A month...
The engine in the Bonneville is known to have problems with the intake manifold, this can cause poor idle and sometimes a smell. The pipe from the EGR valve causes the plastic next to it to melt, sometimes coolant can get into the intake. This needs to be looked at as soon as possible, because water getting into the cylinders can cause major damage.
May 05, 2012 | 1997 Pontiac Bonneville
Hi. I have a '88 Hiace. Recently, very occasionally the headlights failed to work. If i switched the switch on and off a couple of times, they would come on. The other night, i smelt a bad electrical...
yes it will burn out again the wiring from the switch to the headlight module has a short use a voltmeter to trace it and replace wiring then put in the relay
Sep 15, 2010 | Toyota Corolla Cars & Trucks
My e-2 vacuum runs very loud and smell like it's burning.
You may have damaged a bearing or bearing housing and that could be causing the motor armature and field to rub together which in turn causes the motor to draw a significantly increased current to overcome the friction. It could be a simple fix if it is a bearing but if it is the housing then it is likely toast. I used to repair motors years ago and the cost then was not bad. However if the motor is heat damaged, as happened to my power rack last year, it was cheaper to buy a new one than replace the motor. A burned out motor is not worth repairing these days.
Dec 19, 2017 | Rainbow E series Canister Wet/Dry Vacuum
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
I drive 3181 N42 02 Reg. I'v been told the car has oil leak, jus yesterday whilst driving I could smell something like burning metal and a particular noise I don't know where it is coming from. Please...
Let an auto tech look at it because one way or the other it's going to end up on some tech's hands. Burning oil smell must be from the valve cover leak and dripping on top of the hot exhaust manifold burning it. The only time I smelled burning metal odor was from a smelting plant. It had an acidic smell that going to put you in tears.
May 18, 2010 | 1999 BMW 318 ti
MVOHD80 Liquid video car DVD player has audio, but no picture
THAT MEANS UR TUBE IN THE SCREEN IS FRIED, IF SO U HAVE A FACTORY WARRENTY, NOW WOULD BE A GOOD TIMER 2 USE IT
Mar 20, 2009 | Car Audio & Video
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Help with project
Can you post a picture of what the picture looks like, and do you have the service manual for this model?
Mar 12, 2008 | Hitachi 51SWX20B 51" Rear Projection...
24 people viewed this question
 Grubhead
Grubhead
