Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
We fixed the emptying out problem thank you, now the water does not come in. It is connected to the hot water and does not appear to be kinked in any way. If we put a bucket of water in the machine then it all works fine.
  • 1,527 Answers
Hello. should this be connected to the cold water tap as it heats itself the hot water coming could have damaged the inlet value hope it hleps a little
regards
shaun
Posted on Mar 27, 2011
Testimonial: "Thank you very much for your fast reply. Will look into this tomorrow and hope it is as simple as that. Regards"
    Problem Solver:
  • 13 Answers
Ensure that the water line is on/open - it should be connected to the hot water line - if still not working - it is a problem with the water solenoid, most likely the fill solenoid diaphragm is plugged with a little sand/dirt. Recommend turning the water off, take apart the solenoid and clean it under water, along with the strainer etc..
Posted on Apr 22, 2011
My dishwasher is not emptying and the warning light states watertap what is the problem.
Hello William Avant,
(Unless you mean water TRAP)
Water is turned off and/or there is no pinch
or twist in the supply hose...
First check the valve is fully on... then pull the machine away from the wall and inspect the entire length to make sure it is not pinched of kinked.
TRAP (out-put)... in addition to checking the drain hose...
Make sure the connection to the Garbage DISPOSER
has been opened (see DISPOSER owner's manual)...
and follow instructions for connecting DISHWASHER
drain..
Easily tested... (use CAUTION)
Loosen the hose and direct the "out flow" into the sink
(be prepared for the water to be very HOT)
Carnac the Magnificent
Aug 01, 2017 | Dishwashers
Don't think machine is washing clothes in hot water . What could be wrong ?
1) Improper water temperature selection, 2) no hot water to machine due to: a) being valved off, b) clogged filter or strainer, c) kinked hot water supply hose, d) failed hot water solenoid valve or bad / of loose wiring connection inside the washer or 3) depleted hot water in domestic hot water tank due to previous laundry washes / bathing / etc..
May 19, 2015 | Zanussi Washing Machines
Does it heat the water? when I empty the holding tank the water appears not to be hot.
I believe it does not heat water. you put hot water in w/cleaning solution. it is cool by time you empty holding tank.
Sep 03, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Zanussi jetsystem zwf1631w error code20
Hi
This error code indicates a water pressure concern. Not enough water is getting to the machine in the proper time frame. There are a number of reasons this may happen and some of them can be extremely easy and quick to fix.
One of the easiest solutions is to check both the hot and cold water shut-off valves and confirm that they are open as far as they will go. Perhaps the last time someone check the hoses, or moved the washing machine the handle was left off or only partially opened and the F20 error code will appear. Make sure to check both the hot and cold water faucets.
The second option is that you may have a defective hose. If the host has become kinked or in some other fashion damaged it may be stopping or slowing water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Zanussi FJS1225W Front Load Washer
The water does not fill on Model # MFW9700SB0. The leeters F and H appear. The washer is brand new purshaced from EXPO design. We bought it for a house we were building. Just moved in, washer was never...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call- PRESUMABLY UNDER GUARANTEE/WARANTEE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 04, 2011 | Maytag Washing Machines
Hot water is coming into the machine very slowly and then LF code registers on machine-any suggestions on how to fix?
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does ventilate mean?
"Ventilate" simply means that there is an air pocket caught in the system and running water through it can fix the problem. When the ventilate message appears, you will need to run hot water through your steam/hot water wand as if you were going to fill your cup with hot water. If the message does not go away after doing so, you will have to run hot water through your wand continuously into an empty container (emptying one full water reservoir if not more). Once your display screen reads "Select Product, ready for use," you will be ready to brew delicious coffee again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Gaggia Syncrony Compact Digital Espresso...
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Will not wash clothes.
unit is taking to long to fill...check inlet hose for kink,,,check that waters pressure is up...both hot and cold,,,clean your inlet screens ,,clogged..onthejop
Feb 17, 2009 | Frigidaire ATF6000ES Front Load Washer
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
413 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
