Question about Microsoft Xbox 360 Console
Tray wont open
When i push the open tray button, i can 1) hear gears making noise and 2) fan comes on for about 1 sec. but the tray wont open
    Problem Solver:
  • 15 Answers
Well, my bros does that as well. and i just push on the disc tray a little, like push it up if the console is laying down.. it also could mean the motor that pushes the disc tray is off or disfunctional.
Posted on Aug 04, 2008
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
Dvd drive has jammed, and is open about half a centimetre, when it is pushed in it makes a grinding noise like its trying to read a disk but wont click shut or open
Here's the thing...most people and pc makers don't realise you should never push the trays shut. Only use the button to open and close them. The reason being, as I see you have the issue of it, is that the gears can very easily jump. The only way to fix this is to remove the drive, take it apart, {gently} and separate the 2 gears. The one on the tray and the one on the motor. move the tray all the way out, then turn the motor gear all the way around so it matches with the door gears at full out position. close tray. reassemble, put back in and try it out. If all goes well, you just saved yourself a few good bucks. good luck.
Oct 11, 2009 | Computers & Internet
Wondering if anyone is any good with lite on shm 165 drives? Been trying to figure out why it wont open the disk tray. No disk inside, pressing the button makes an audible clunk noise. Pushing the pin...
Problem found on mine: tray opening mechanism is belt driven, while others are gear driven, belt tends to stretch with time and slips on motor pulley, gears do not. Just cheap built. Remedy= Belt can be removed from front with open tray, soaked in rubber rejuvenation liquid for few seconds, cleaned and dried, re- installed on pulley.
It works now, but for how long, I have no idea.
Aug 15, 2009 | Lite On SHM-165P6S DVD RW Dual Layer...
CW068 D drawer wont open-it makes a noise like it trying but wont
insert a bent straight paperclip into the little hole on the face. It will manually push a gear to open the tray
Dec 25, 2008 | CyberDrive CW068D CD-RW Burner
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Original xbox wont load and tray wont open
Ouch, horrible problem.
Try these:
1. hold the eject button for 30 seconds
2. leave the xbox off for a few minutes
3.try a new outlet[may not have enough power to do anything]
4.get a new power cord
Hopefully this helps
Dec 28, 2007 | Microsoft Xbox Console
Xbox 360 drive doesn't always open
Can you hear any gears grinding when you try and eject it? Has anyone ever pulled or pushed the tray in roughly?
Sep 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
115 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
