Question about Kidde Nighthawk Combo Gas/co Detector
Single continuous beep of co detector - Kidde Nighthawk Combo Gas/co Detector
    New Friend:
Check - Your middle battery is installed incorrectly!
Posted on Oct 24, 2014
CONNECT THE UNIT OUTDOOR UNDER CLEAN AIR IF IT PERSIST, REPLACE THE UNIT.
Posted on Apr 03, 2011
Co detector garrison 46.0019.0 of may 2011 Rings continuously until batterynew removed
Junai, Try to vacuum/blow dust out of detector, if this does not work detector faulty and will need replaced. Most detectors have a label stating replacement date or expiry. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kidde.com/home-safety/en/us/co-safety/about-carbon-monoxide-alarms
Looking for Answers about Garrison Garrison Plug in Carbon Monoxide Alarm
Why is my Carbon Monoxide Detector Beeping with pictures
Jun 19, 2016 | Alert Home Security
Tip
Beeping CO detector
If you have an alarm system with a CO detector on it and it is beeping every 5 min or so it needs to be replaced, Contact your security alarm company. CO detectors only last 5 yrs. Note: Nothing will be indicated on keypad so be sure it is part of alarm system or you may be charged if tech comes out. When in doubt call them out. : )
on Mar 07, 2010 | Home Security
4 beeps with pauses for 2 year old carbon monoxide detector
I'm pretty sure that indicates an alarm. The pattern is referred to as "temporal 4" which is the alarm pattern for CO. Either your device is in a bad place or there is an intermittent CO leak which is exceeding the ppm (parts per million) threshold for a given time period. The instructions for the device will tell you what that number is. If you have more than one of these, I would try swapping them to determine if the problen is with the device or the location. Good luck!
Apr 24, 2015 | Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire...
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Hi, I have two of your Nighthawk Carbon monoxide detectors, both under 2 years old purchased from Menards. about a month ago the one in the garage started beeping continuously saying it needed a...
Carbon monoxide detectors have a fixed life span. You did not post the model number and there is no way to tell how long it ago it or the parts in it, were made.
Mar 18, 2017 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk carbon monoxide detector started beeping every 30 sec.pressed reset button on front beeping continued louder, put unit ouside in fresh air for few secs beeping stopped. I opened the...
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
Dec 20, 2010 | Kidde Nighthawk Combo Gas/co Detector
Single Loud Beeps every 15 to 20 minutes followed by a sentencein French?
hello, your batteries may be to low, this happens to warn you that you need to change the batery normally thats what this will mean unless the unit is fualty, get a fresh set of batterys and see if that helps.. if not get a new detector, good luck hope this helps..
Jun 05, 2010 | Kidde DC Voice-Alert CO and Smoke Alarm
Periodically emits 3 loud beeps. Displays 888.
The CO detectors require replacement of the battery periodically.
Unlike smoke detectors, the detector element itself also requires replacement as well as the battery and is sold as a module with the battery attached.
May 02, 2010 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kidde Nighthawk Combo Gas/co Detector Logo
352 people viewed this question
Top Kidde Home Security Experts
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
