Question about Transcend T.sonic 610 MP3 Player
Automatically power off
when ever i power on my transcent mp3, its automatically gets power off with in 30 seconds to 1 minute, kindly do the need ful.
my email id is - gvenkatesh1978at yahoo.co.in
  • rohit saluja Aug 07, 2008
    my T.sonic 610 mp3, 512 mb is made to wrk for 14 hrs after full charging.
    but it gets off itself before that and its not get detected on pc for few hrs.
    pc detect it after one or two days by itself.
    please help. i want to use it everyday.
  • 9 Answers
Charge your mp3 player continuously for 3 hrs.
procedure:
1. use cable that is provided to connect computer(usb socket) and mp3 player.
Posted on Aug 04, 2008
Screen keeps getting darker
Click on Settings>Display>General:
1) Brightness>Uncheck Automatic brightness, set the brightness you desire and tap OK.
2) Back to General> Screen timeout>Select a time greater than 15, 30, 60+ second/minutes. Personal preference is 30 minutes when watching movies, videos, or reading.
Sep 23, 2014 | Samsung Galaxy Tab 101 Tablet...
Formet error in my player how to solve
I'm sorry to know that the Format error is displaying in the Walkman Player. I'll be glad to assist you with this.
Follow these troubleshooting steps to resolve this issue.
Because each of these steps represents a possible solution to this issue, check the device status after completing each step.
The NO DATA or FORMAT ERROR message may occur if the portable player has been formatted using the format utility in Windows Explorer. To correct this issue, initialize (format) the portable player using the Initialize or Format utility built into your Walkman player.
Reset the unit by pressing the RESET button with a small object such as a paper clip.
Disconnect the power source (if applicable) for 30 seconds.
If using AC power, verify that the adapter is securely connected and plugged into a working outlet.
If the unit does not work after the 30 seconds, remove the power source (if applicable) for 30 minutes or turn off the player for 30 minutes.
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required .
Thanks for contacting FixYa
Aug 08, 2011 | Sony NW-E507 MP3 Player
My sony prs 350 ereader screen froze when i was reading my book when i try to turn it off the light turns red and it is fully charged
Hi!
If the Reader is frozen, you can try the following:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
eBookBoy
http://digialreader.freeforums.org
May 06, 2011 | Sony E-reader Portable E-book MP3 Player
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have a transcent tsonic 610 1 gb pen drive..
why do you want to format it and it will not let you format it because it has the files in it to let it know how to work you should just be able to drag and drop your music to it or whatever you want to put on it
Aug 07, 2009 | Transcend T.sonic 612 MP3 Player
Copy, rename files which has same filename
Ok. Try Renaming these files as 1.wav, 2.wav and so on....
Then try doing what you want to do with them.....
Jan 30, 2009 | Audio Players & Recorders
PEN DRIVE DRIVERS
DEAR SIR, I AM HAVING KINGSTON MAKE PEN DRIVE WHICH DOES NOT SUPPORT WINDOWS 98.KINDLY SEND ME A DRIVER FOR WINDOWS 98 WHICH SHOULD INSTALL ON MY PC AND ABLE TO WORK ON IT.
Jun 06, 2008 | Pen Drive IVO MP3 Player
FORMAT ERROR
u must to format it in FAT not FAT32
Jan 29, 2008 | Sony NW-E002 MP3 Player
Monitor turns off
sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Jan 29, 2008 | CTX S762A 17" LCD Monitor
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Transcend T.sonic 610 MP3 Player Logo
44 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
