Question about GPS
My magellan 1200 is very strange....it works fine and holds a charge ..i got a new battery.ive been charging it through the usb cable when its off ..takes about 6 hours or so to get a full charge then it works for like 2-3 hours....when i plug it into my car adapter it acts like i pluged in the usb cord to up load new software or maps....i took it to best buy to see what they said and this is what happen ...they plugged it into different car adapters that they have for there units in the store that they are selling and some of them brought up the screen usb has been plug in.....and some of them would show that i was charging the unit and i could go do the usual stuff (thats what should happen)...when the screen says usb post connected i cant do anything..i tried to reset it a bunch of times and nothing diff. also i held the on button for 20 seconds when i turned it off...i contacted support at magellan and they were no help....please help just so u know it does work and its not stuck on that screen unless i plus in my car adapter
SOURCE: Won't turn on after first time
saw this on a different forum.....I got one for xmass.....hope it doesn't happen to me!!!!!!!!
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Posted on Dec 26, 2007
  • 20 Answers
SOURCE: RoadMate 700/760 Version 6 update maps are over a year old!!
THE CURE for this problem is NEVER BUY Magellan again!!
After paying over £800 for an early Roadmate 700 (which failed and was replaced by a failed/recon version) then to have problems with software.. now having waited a year to get map update and version 6 firmware I find it doesn't give me Magellan Tools which was promised by Magellan Support.
After several mail queries and important qustions remaining unanswered I am buying a Tomtom Go 720T which will do all the updates automatically via a cradle linked to my PV/Internet.
NEVER EVER AGAIN a damned Magellan - great when it works but it's easier to get blood from a stone than good support from Magellan.
Posted on Jan 08, 2008
SOURCE: supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Posted on Jan 20, 2008
SOURCE: gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Posted on Feb 26, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
Will not hold battery charge
If the battery is one to three years old, chances are it will need to be replaced, the fact it will not hold a charge is a sign the rechargeable battery needs to be changed.
Mar 26, 2011 | Magellan Roadmate 1200 Car GPS Receiver
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
I pluged in my Magellan Roadmate 1200 in to the computer with the usb cable thinking it would charge. It now says it has a fatal error and that screen won't go away. Did I erase the memory on it? I...
im sure its not trash, but i dont think the usb will charge this model ( the usb wont charge all models of magellan, only some) while the unit is on, use a paperclip and insert it in the small hole on the side of the gps, that should return it to its normal state.
if you need further help, just let me know.
bill
Sep 03, 2009 | Magellan Roadmate 1200 Car GPS Receiver
The battery will not charge on my magellan 1200
try hold the power button for upto 15 seconds but i suspect the power port might be damaged due to magellans poor design, you can contact them here
Jul 21, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Not booting. possible charging problem??
the usb connector block on the unit may have actually broken off from the main board. I thought I had a charging problem too until I opened the unit.
Apr 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I just got a Magellan roadmate 1200 over the weekend from a friend and when I plug it in it loads to a screen that says the usb is connected follow pc instructions
The USB must be for charging the unit and downloading updates when it becomes available. You have to unplug the USB and use the battery power to put in addresses .My 1200 does the same.
Jan 05, 2009 | Magellan Roadmate 1200 Car GPS Receiver
I have a goodmans gmp38g6 mp3 player its new and battery run out for first time today so ive pluged it in usb to charge and nothing happens ive tried usb port with my camera thats fine and ive tried usb...
Press and hold the reset button (located underneath the hold switch) for 10 seconds. If there is still life in the battery it should start working. If not then if should begin charging when plugged in.
Hope this helps.
Andyj76@btopenworld.com
Oct 18, 2008 | Audio Players & Recorders
GPS Logo
32 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
