Radio turns off after one minute - Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
'radio'? What product are we talking about?
IF it has an amplifier...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Mar 27, 2011
Philips car radio CEM2100/05 Turns on and off
Pull the radio and send it out for repair.
Apr 29, 2016 | Cars & Trucks
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
Why does the radio go off after a few minutes
check the operators manual and check for a sleep setting. Adjust it to off
Oct 09, 2014 | Cars & Trucks
How do set the clock on my 1998 chevy Malibu radio?
If the radio has a set button: Turn key on and radio off. Press the set button and use the right seek button to set the minute and left seek to set the hours. If it has no set button: find the hour and minutes buttons or holes under the auto tone knob. Turn key on engine off and radio off. press the left button for the hour and right button for minute.
Sep 18, 2014 | 1998 Chevrolet Malibu
Why would my van radio stay on after I turn the car off and open the door?
Does the dome light come on when you open the door? It should work off the same trigger.
Sep 04, 2014 | 2006 Chevrolet Uplander
What is the function of the sleep button on the TruTech TCR1276 Clock Radio. The alarm clock already has a snooze button.
The sleep button sets the radio to play for a set length of time and then turn off. Thus you can fall asleep with the radio on and not have to remember to turn it off. It works when the clock's Auto/On/Off switch is set to Auto or Off. The default is 59 minutes before it turns off. You can adjust the time until it turns off by holding the sleep button and the hour (lengthen the sleep time) or minute (shorten the time until it goes to sleep) button. The longest duration is 1 hour and 59 minutes until shut off.
I hope this helps. You can find the manual for the clock radio at: http://www.curtisint.com/support/manuals.asp . Search for the TCR1276.
Jan 08, 2011 | TruTech TCR1276 Clock Radio
2010 Mustang - Radio just stopped working. The display only says "Mustang" with temperature reading. It should display time, channel, etc...No controls operate. Worked fine...turned car off..15 minutes...
try disconnecting power to the radio for a few minutes and see if it resets itself. if you can't get to the back of the radio, disconnect the battery.
Aug 23, 2010 | Car Audio & Video
The radio in my 2002 Jeep Liberty re-starts every time the minute on the radio changes. Also, the CD player re-starts, so every minute it starts at the beginning of the CD. The sound turns off...
is it a factory radio??? if it aftermarket radio could be loose conection on one of wires but sounds more like the radio has a short inside the radio it self you probley have to replace the radio
Mar 12, 2010 | 2002 Jeep Liberty
Can't get radio primed to let me enter the security code in acura
disconnect the battery for a few minutes..or pull out the radio / back up fuse or the ecu fuse...then insert ur radio code....
Apr 14, 2009 | 1999 Acura TL
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
22 people viewed this question
 Grubhead
Grubhead
