Question about Nikon COOLPIX S570 Digital Camera
My camera lense is stuck out and when I turn on the camera it makes a funny noise and says "lense error" on the screen. Is there anything I can do to fix it myself before taking it to get fixed?
    Scholar:
  • 80 Answers
Sounds like the camera lens is jammed. Before you take it to become repaired, try cleaning the crevices of the lens module to make sure there isn't any loose dirt or debris in there. Try applying very gentle pressure to the lens and see if it retracts or moves.
If it still won't budge, it's probably an internal problem with the mechanism retracting the lens, there's not much you can do but send it off to get fixed.
Cheers!
Posted on Mar 27, 2011
I can't turn my camera on,I press the power button,it gives me a whirling noise,the lenses come out(but not all the way),the picture on the screen is blurry,and I can't make a shot,and after2 seconds the...
sounds like it might have got a bang,you'll have to take it to the shop,make sure you get a quote before you get any repairs done,camera repairs can be expensive.
Mar 18, 2010 | Olympus Stylus 700 / 700 Digital Camera
Hi, my Nikon Coolpix s210 displays a Lense Error and the lense extends out, makes noises then retracts with the screen displaying Lense Error. Any help would be appreciated. Thanks
you should take it do the shop because somthing might be stuck or it could have a malfunction well i dont no exactly i jus say go check it out
Oct 11, 2009 | Nikon Coolpix S210 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
Broken Lense
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 30, 2009 | Sanyo VPC-E760 Digital Camera
Lens error causing camera to not work, HELP!!!
I just had the exact same problem on a friend's Exilim EX-Z75. Since it was useless as is, I was asked to investigate. It turned out to be a mechanical problem in the lense. I'm not too sure if it was a misalignment of the servo motor or if a gear popped out of a guide hole. In any case, if your lense goes in and out as it normally does, the problem is not in the main motor, but in a smaller internal secondary motor that adjusts the focus. Only try this if you are comfortable working with small tools and have plenty of patience. Took me about 3 hours start to finish. Warning: there is a capacitor that can hold a good enough charge to give you a jolt, possibly causing you to drop or damage the camera beyond repair, or short out your pacemaker. Keep your hands clean and avoid touching the circuit board and lense and display surfaces. Just in case you do get the camera working. Cycle the power button until the lense retracts completely. Remove the battery. Remove the case screws (6 on the bottom and 8 on the sides) and carefully remove from internal camera. The lense assembly is held in by some soft spongy spacers and a clip on the bottom corner of the lens compartment. Push the clip and the lense assembly should flip up revealing the back of the lense. Be careful to not put too much tension on the flexible circuit board. The CCD (that captures the picture) in the middle is held on by two screws. Remove that first letting it sit in the lense compartment. Then there is a circular plate that will reveal the focusing motor and gears. Remove the 6 screws and carefully remove the plate. There is a small motor and 3 gears that will be exposed. The center one might pop out. If it does, the small gear on the dual gear assembly faces down. You should be able to pick up the center focus unit high enough to make sure that the focus gears and rods are properly lined up in their guide holes and check to make sure none of them are stripped or out of alignment. The focus rods should be paralell to one another on the side of the focus unit. This is what I believe is causing the lense error problem. I would suggest after checking the alignment that you manually turn the gears so that the lens is all the way up. Turn the brass gear on the motor to make sure that all the gears are turning and moving the focus lense. If you think you have everything aligned properly, it's time to re-assemble the camera. Once you have the back plate and CCD put together, you could try to put the battery back and power up. If everything is ok, you should see a picture on the display and be able to take a picture. (Watch out for that capacitor.) If not, you might want to take it apart and recheck the alignment of the focus gears again. I had to do it twiceeven though it looked ok the first time. Remember, anything not lined up properly in there will cause the camera to malfunction. You should also have a greater appreciation for how sensitive a camera can be. DON'T DROP IT! Good Luck. Phil
Mar 15, 2009 | Casio Exilim EXZ75 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
It sounds like. You really need to have some one take it apart and clean the sand out of it. The camera will make those noises when the sand gets between the gears of the lens assembly and they cant connect correctly.
ou could try helping the lens go back in GENTLY. But thats risky and you could ruin a lens that would work just fine if it where cleaned out.
let me know which model and brand you have and I could tell you better whether or not you should try anything your self.
goodluck,
Caleb
Jun 30, 2008 | Cameras
Lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Nov 13, 2007 | Kodak EasyShare M853 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
150 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
