Question about Electrolux Cucina Pro 1711 10-Cup Coffee Maker
The EES00 voltage is 220-240V 50Hz Our current is 220V 60Hz Can it be used?
    President:
  • 2,468 Answers
Usually it will work,but if it has a timer or clock on the unit the time will be fast due to the frequency difference,but all else should work fine
Posted on Mar 27, 2011
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
Is it possible to use this turntable from UK 220V 50Hz, in the US 110V 60Hz?
Go to Radio shack or other electronic places and buy the correct converter for it.
May 18, 2015 | Audio Players & Recorders
How to operate a AEG Washing Machine Electrolux 50hz with 60hz power supply?
In general, it is NOT recommended to operate an appliance 50hz-to-60hz OR 60hz-to-50hz UNLESS the manufacturer specifically says it can do it.
Additionally, you must also account for the voltage (110V vs 220V), which you have not indicated.
Therefore, it is best to get your exact model number and contact the manufacturer, but get ready for disappointment. The larger and more complex the electronic device, the less compatible it is.
Good luck.
Mar 19, 2015 | Electrolux Washing Machines
Input voltage?
Input voltage is an electrical characteristic of the electricity coming from your wall outlet and into your appliance. It depends on your location in the world. In the US for example it is 110V 60Hz. In Europe it's 220V 50Hz.
Apr 07, 2014 | Televison & Video
I have a Netgear wireless router WGR614 v5 with the AC adapter of 120V-60Hz-16W. I've moved to Europe where the electricity is 220V. Can I use an AC adapter of 220V for this wireless router? Thanks a lot...
Yes, make sure you have a new power supply with the right voltage output, enough current (if the new power supply is rated for more current output, it will be OK), and the right plug with the right polarity.
Check your power supply, some will actually work with a wide range of voltage, some actually go from 100-250VAC. 50Hz-60Hz
Jan 05, 2011 | NetGear WGR614 Wireless Router
Can I use my EuroPro 416 Sewing machine with 220V electricity?
A transformer will not change the frequency of the supply, only the voltage.
It may be possible to obtain a box of electronics to convert 50Hz to 60Hz, which would solve the problem.
A machine designed to run on 60Hz will run slower on 50Hz and may run hotter. If it burns out due to overheating, then a new motor designed to run at 50Hz should be fitted. You could have peace of mind if you fitted a new motor (which might be cheaper than an electronic frequency converter.
Jul 25, 2010 | Euro-Pro Sewing Machines
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Voltage difference
The voltage difference can be overcome. The problem will be the difference in frequency 50hz vs 60hz. The motors would have to be replaced with motors designed to operate at 50hz. The electronics would most likely need to be replace as well.
Best bet would be to contact whirlpool international to see if the offer a conversion kit/package.
Feb 02, 2009 | Whirlpool LER5636P Electric Dryer
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Electrolux Cucina Pro 1711 10-Cup Coffee Maker Logo
118 people viewed this question
Top Electrolux Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Electrolux Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
