Some chanels is locked by child lock how i can unlock them? note: ihave not the original remote control and any way can be done without remote?
    Scholar:
  • 113 Answers
Call the maker of the tv and they will tell you what you need to do ,look at the user manual first and look in the parental control section for resetting without the password.Good Luck
Posted on Mar 27, 2011
I waqnt reseat child lock off witout remote controal i dont have a orignal remote controal tv digihome model no32723hd
It might be impossible to release the child lock, without its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 26, 2014 | Digihome LCD TV
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Awa lcd ltw32ds
You need the original remote control to unlock the TV.
Jan 01, 2018 | Televison & Video
I want to unlock the child-lock key without using a remote control as my remote control is not working, and now my television is stuck on AV. mode. I cannot move anywhere... Please help!!!
Different brands use different methods---many RCA sets it can be done manually by holding the vol up and channel up together for over 10 seconds.
Other brands require the original remote and a 3 or 4 digit number code.
Dec 07, 2012 | Televison & Video
I want to unlock the child lock key on my LCD TV
Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
Dec 05, 2012 | Televison & Video
Need a replacement remote control. also tv is stuck on child lock
Hello
If the tV is strucked at child lock, you must have its original remote control to unlock it. Just contact the nearest Maganvox authorised service center for details.
Mar 01, 2012 | Philips Magnavox 27MS343S 27" TV
The television has somehow gone into child lock mode and we have no remote control. Please advise how this can be removed without using the remote or please could you supply an unlock code which can be...
Unlocking child mode lock it is very difficult and nearly impossible without the tv original remote and the secret password word.Tries tv unplug,replug the tv back like about 24 hrs later.That all u could do,some tvs will reset itself and erase the password.
May 07, 2011 | Televison & Video
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
Lack key appear on my flat screen
Do you use the remote control or buttons on the tv itself? Many TVs have a child lock feature that will prevent operating the TV without the remote control. If you use the remote control you should be able to change chanels, and to disable the child lock from the menu.
Mar 09, 2007 | Sony 21" Trinitron P202 Flat Screen...
Open Questions:
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
