Question about LG 42LC2D 42 in. LCD HDTV
Picture distorted goes red in color after 1 hour
    Scholar:
  • 113 Answers
Most likely the problem is bad capacitors on the video module of unit.If you take the back off you should see basically 3 circuit boards-Power Supply,Main Board,T-Con Board.Inspect the main board and the power Supply Boards for bad capacitors,in most cases the bad ones will usually have a bulge on the top of the capacitor,a normal cap will have a flat top,if you find any of the caps have a slight or big bulge,as if they were getting ready to explode,they need to be replaced with the same microfarads and voltage rating which is printed on the side of each cap.Replace them one at a time,you will need a soldering gun ,solder and solder wick to properly do the job.You can find all the tools you need at your local radio shack.The solder wick is used to extract the old solder so you can put a new cap in,the caps will have 2 legs.Also you must look at the cap and line up the negative side of the cap to the negative symbol on the board,there should also be a plus symbol where the cap goes in on the board.Good Luck and let me know if you need more information.
Posted on Mar 27, 2011
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Wavy line goes through picture during color changes,picture cut off on bottom
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Apr 25, 2010 | Hitachi 60SBX78B 60" Rear Projection...
After a half hour of operation, the picture begins to shadow.
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 50UX57B 50" Rear Projection...
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
The Picture on my x box goes distorted and pixelated
yes but an hardly wet towel on it then leave it for 45 mins
Feb 19, 2010 | Microsoft Xbox 360 Console
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
Symptoms:
  • Colors wont align
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Panasonic PT-52DL10 DLP TV
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Feb 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture goes out periodically
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Sep 24, 2007 | Sony KP-61S75 TV
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
LG 42LC2D 42 in. LCD HDTV Logo
55 people viewed this question
