Question about Foxconn Computers & Internet
I have reinstalled Windows XP Professional 2002 and I have no sound, I don't even have the sound icon in my taskbar, i have gone into device manager but could not find any problems in audio
  • Foxconn Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 27, 2011
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
I need a sound driver for intel pentium 4,3Ghz processor os windows xp professional service pack 1 pls urgent give a download link
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
The volume icon on my taskbar has been deleted from my computer how can I download it again
Missing icon from taskbar
1. If you have uninstall your Audio drivers from your system the volume icon will not show in the taskbar. You have to reinstall the audio drivers to restore the volume icon back to the taskbar
2. If the your volume icon is missing from the taskbar and you did not uninstall the audio drivers, then go to Start -> Control Panel -> Sounds,Speech, and Audio Devices -> Sounds and Audio Devices ->"Place volume icon in the taskbar" box -> Uncheck & check -> Apply & OK and your volume is restore at the taskbar. (Reboot if necessary)
Hope it helps.
Nov 22, 2010 | Microsoft Windows XP Professional
My pc is not showing the volume icon my os is windows xp professional version 2002 sp3, v.3311 in sounds and audio devices properties it is showing no audio device
Please reinstall your sound driver properly. when sound icon do not show in the bar,this is only solution for it.
JAIN_IT {INDIA}
Sep 16, 2010 | ASUS M2N68-AM SE2 Motherboard
No sound, get active mixer devices message and code 28
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application
Sep 10, 2010 | Microsoft Windows XP Professional
Sound icon not here
To place a volume icon and sound icon in the taskbar follow these steps.
For Volume icon:
1. On Control Panel, double click Sounds & Audio Devices icon.
2. Select Volume tab
3. Check the box for "Place volume icon in the taskbar"
4. Click OK.
For Sound Icon"
1. On Control Panel, double click Sound Effect Manager
2. Select General tab.
3. Check the box for "Show icon in system tray"
4. Click OK.
I hope that solves your problem.
Please comeback and rate this answer. Thank you for using Fixya.
Aug 16, 2010 | Microsoft Windows XP Professional for PC
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
I don,t have sound cord in my pc
Click on Start, Settings, and launch Control Panel. Double-Click on the "Sounds and Audio Devices" icon. On the Volume tab, make sure the box, "Place volume icon in the taskbar" is checked. Uncheck "Mute" if it's checked.
Mar 22, 2009 | Microsoft Windows XP Professional
No sound for windows xp.
Go back into your device manager. Rught click on your sound card or sound device and say uninstall. After it is uninstalled, don't close device manager. Go to very top to your your computer's name or my computer if you didn't name it. Right click and click on scan for hardware changes. Windows will find your device and reinstall in a second. This will give you cack your volume control and sound.
Mar 17, 2008 | Microsoft Windows XP Professional With...
Sound decoder
Go to control panel --> system --> hardware >> device manager.
If you have problem with driver, there will be a big yellow question mark in your "audio controller". If there is problem, you have to reinstall your audio-driver.
If it is ok, then back to control panel -->sounds and audio devices. In tab "volume", you can see if your system might be "mute" (do uncheck box of mute). And if your volume icon is not in the taskbar, do check the checkbox of "place volume icon in the taskbar".
You can also modify the speaker performance here.
Feb 29, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
42 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
