Question about Sony Vaio VGN S1XP Laptop Universal AC Adapter 15-17v (AC22VPNNA9JEB)
I can't log on bios for sony VGN- S1xp - Sony Vaio VGN S1XP Laptop Universal AC Adapter 15-17v (AC22VPNNA9JEB)
  • 206 Answers
Please restart the computer and try pressing the F10 or F8 Key to enter BIOS Setup. If the issue persists then it might be with the Keyboard or Hardware issue. In that case please contact Sony Service Center.The AC Adapter has to be used which is compatible with the particular model of the Notebook.
Posted on Mar 27, 2011
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
I cant remember the bios password of my notebook model sony vaio vgn-a497xp
You can reset the BIOS password. To reset the BIOS password read the information from this link.
Feb 24, 2011 | Sony VAIO VGN-A497XP PC Notebook
Install wrong bios on sony vaio laptop model vgn cr 353 so dont see anything in bios setup or some garbeg seen in bios cant acess bios
BIOS is gone...u need to change the BIOS IC or may be the full Motherboard...
the other option is to go to tech shop and "TRY" have ur BIOS flashed with the correct BIOS software...
Feb 05, 2010 | Sony VAIO VGN-CR305E/R Notebook
My friends sony vaio vgn-s1xp has all drivers except for the audio drivers. i have searched for days and cant find them, could someone help me please ?
i've just install xp windows to my sony vaio vgn-fs285h and i can't adjust brightness on screen, can anyone help
Jan 08, 2010 | Sony Computers & Internet
VGN-S1XP laptop will not power up despite resetting it.
have you tried taking the battery out and powering up without it in, if you get no power at all your charger is more than likely at fault. if you can power up then it is the battery or connections that are at fault
Oct 26, 2009 | Sony Computers & Internet
Sony vaio VGN-S56GP pawer on Bios password
Hello, I can unlock ANY  SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto conradodav@hotmail.com WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
Feb 11, 2009 | Sony VAIO FX140 Notebook
Bios on laptop
Its either F2 or F3, Sony vaion use them both.
During starup press one off them
Good luck
Dec 10, 2008 | Sony VAIO VGN-FS640W Notebook
Sony vgn-s1xp won't power up
Hi
Follow the procedure below to troubleshoot no power or the VGN-S1XP (VGN-S360) does not turn on.
While following this procedure, note the LED status at each step. This will provide additional information for further troubleshooting.
NOTE: Some computers are designed with hooks above the LCD screen that secure the lid when closed. A switch inside the holes below the touchpad [picture attached] detects when the lid is closed and latched. If the switch is stuck, the computer may not turn on properly. Check to make sure the switch is working properly.
Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
NOTES: Do not connect the AC adapter to a surge protector or extension cord. If the DC jack on the computer is loose or damaged, the computer may require service. Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged or the LED is not lit when plugged into a working AC outlet, the adapter must be replaced.
1. Attempt to turn on the computer. If same, press and hold the Power Switch for 15 seconds and try again.
2. If issue persists, remove the battery; disconnect the AC power adapter; press and hold the Power Switch for another 15 seconds.
3. Connect the AC power adapter. Attempt to turn on the computer. If the computer turns on without the battery, connect and charge the battery for 24 hours.
4. Disconnect all external devices that are connected to the computer. These devices include, but are not limited to, a modem, floppy disk drive, network connection, USB device, printer, keyboard, or mouse. Attempt to turn on the computer.
5. If issue persists, remove any additional Random Access Memory (RAM) that was installed in the computer and attempt to turn on the computer.
6. If same, remove all RAM and attempt to turn on the computer. Note beep codes and pattern.
Ensure to remove battery and disconnect AC before opening up the laptop to remove RAM. Electrostatic Discharge (ESD) precautions should also be adhered to.
NOTES: The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. (In this case, the system board and or other parts may likely be faulty.)
Regards
Mike
Mar 25, 2008 | Computers & Internet
Blue Screen
Please try changing RAM. If same thing continues try logging on to safe mode by booting in safe mode( By pressing F8 during boot after bios check).and restore the note book .
Else Try reinstalling the operating System.
Mar 06, 2008 | Sony VAIO VGN-N250N/B Notebook
Sony Vaio VGN S1XP Laptop Universal AC Adapter 15-17v (AC22VPNNA9JEB) Logo
131 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
