Question about Canon PIXMA MP810 All-In-One InkJet Printer
My canon MP810 all-in-one printer, i've cleaned the printer head, and i have replaced the ink cartriges with new Canon brand, but till got error code U052
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position. Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center.
Posted on Mar 27, 2011
Only half of the page prints why (canon pixma mp810)
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
Sep 05, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Have error message UO52 print head is incorrect, have installed correct ink cartridges what do I do ?
It could in fact be a defective print head problem but try cleaning it first:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Jul 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Just replaced the black ink PGBK on my Cannon MP810 printer and kept getting error msg "wrong printer head". Took printer head to World Cartridge and they cleaned but still get the same msg....
Dont go to Cartridge World :(. This problem is sometimes caused when a cartridge has been re-filled and re-set too many times, The chip corrupts and causes some very weird messages. Simply try a New Set of Cartridges (Not reconditioned or Refilled). GnL Products in NSW have new compatible cartridges for about $10 each. gnlproducts@live.com.au
Apr 04, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Canon mp810 is not printing correctly
Brand new cartridge or refilled one? If refilled cartridge, just wait for 30 minutes after refilling and use good quality of ink. It's caused by bad ink flow. While ink spray (bubbling) form head, ink at ink tank not flow to head.
Feb 02, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How do I remove the print head from my Canon MP810 printer for a clean? :o)
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Jan 11, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP520 error U051 insert print head, no print head. This is a new printer that was not used for 4 Months. What do I do?
The printer not recognize the print head at the moment.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Clean the contacts using cotton and some alcohol.Then put all back and try again.If this not help you need to replace the print head.It's part number is QY6-0070
Oct 30, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP810 Error Code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 22, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Prints with a pink tinge
Have you tried cleaning the print heads using either regular or deep cleaning modes? You should be able to access this through the software options or on the printer itself. You might also manually clean the ink cartriges with a tissue.
Dec 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
577 people viewed this question
old marine
old marine
