Question about Goldwell Topchic Effects Highlight Color 2 + 1 Tube ReNew Mix
I'm using Goldwell 12BG which says 2+1 on the box. Is the formula 2 oz. of developer/peroxide to1 oz. of toner or is it 2 oz. of toner to 1 oz. of developer/peroxide and should I use 20% or 30% volume? Many thanks!
Ratio is always developer to color, so a 2:1 is 2 parts developer to 1 part color. Example mixture is 40 ml developer to 20 ml color.
30 vol gives you better control and less damage to your hair. If you have VERY dark hair (level 5/4 or below), you need to pre-lift and then apply the color. It sounds like you're not a trained stylist, so I don't recommend 40 vol as it lifts too fast for most people to get an even application, especially if you're applying it to your own head (since it takes longer to do generally speaking).
You can work in sections to preserve color and get a more even application. Simply mix enough color for one section at at time, apply and process, then rinse ONLY that section with water to stop the chemical process. Repeat on all other sections. Good luck!
Posted on Mar 29, 2011
What is the corn and oil amount for treat time popcorn popper tpc 603
I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
Jan 22, 2016 | Kitchen Appliances - Others
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
How much water with how much Roundup ?
Assuming you are using the concentrated Roundup formula mix your application equal to a 1% mixture for common grasses and 2% for more difficult weeds. A gallon equals 128 ozs. so we're talking 1.28 oz and 2.56 oz respectively.
Sep 30, 2014 | Roundup "" Weed & Grass Killer
My Yorkie has developed issues with his gums
Stop using them and give him something else your vet will recommend.
Dec 11, 2013 | Generic Minties from VetIQ Small Dog...
Topchic 12bs did not color hair
Try 2 0z of 40 volume goldwell developer to 1 oz 12bs topchic color. process at least 45 min
Jan 13, 2013 | Goldwell Topchic Hair Coloration 2 1 Tube...
1. Can I use mousse and hairspray after I apply Grecian Formula 16 liquid? 2. Do I have to wash out my hair if it has mousse/hairspray before applying Grecian Formula 16 liquid?
no you this is not a good design you first use mousse at night to go to sleep or 3 hour before bath then you use your spry
for more health info http:www.homeoinformation.blogspot.com
Jun 25, 2011 | Grecian Formula 16 Hair Color Liquid...
I want to go from dark brown hair to a platinum blonde with as little damage as possible. i already have the bleach powder, the cream peroxide developer, the activator, and the demi-permanent creme color....
I would honestly pay to go and get your hair done only because with personal exseperiance the cream peroxide and bleach powder fried my sister in laws hair so bad that she had to go get her haid stipped professionaly. If you don't mix the formula right you can actually loose your hair. That's just my exsperance.
Apr 24, 2010 | Health & Beauty
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Goldwell Topchic Effects Highlight Color 2 + 1 Tube ReNew Mix Logo
335 people viewed this question
Top Goldwell Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Goldwell Health and Beauty Expert? Answer questions, earn points and help others
