Let me know prise of ic - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,767 Answers
Hello
What is the number of the IC you wants. Without it, how can I give you the price of it. Provide by Fixya please.
Posted on Mar 27, 2011
Farmville taking away prises, and not letting things go thought
that is a farmville issue we don't adjudicate the farmville or facebook platform here at fixya
May 31, 2012 | Zynga FarmVille by Zynga
How do I open DUET - 2.0 COMPUTER SPEAKERS BLACK
You need to gently prise off the front speaker grill. You could use a blunt pen knife to do this. After you remove the grill You will see 4 additional screws at roughly each corner of the front panel. Unscrew them and then you can use the pen knife once more to prise apart the speaker housing. Prise the housing apart from the top because two base pads hold both halves together at the bottom. I hope this helps! :)
Feb 06, 2012 | JBL Duet Computer Speakers
Hi there! Does anybody knows how to open, a 671R1P109J remote control for a DR-175 dvd recorder. It used to work, but now after some time unused does not. I tested the IR LED with my phone camera, it...
most remotes are held together by one or two screws in the battery holder . Once they are removed you should be able to prise the top and bottom of the case apart using a piece of hard plastic or a plectrum(what guitar players use) prise it apart round all sides and bottom and you should then be able to pull it apart. Also check if there are any labels on the remote and that no screws are hiding under them
Mar 07, 2011 | Televison & Video
*,#,o right cursor and down cursor r not working in my cell nokia-5130 i took it to the shop they sai that its ic need to be changed what shud i do???????
FIRST CHANGE YOUR KEYPAD BEALT ITS PRISE IN INDIA HALL SEL 120.00
THEN KEYPAD ICS PROUBLEM SO CHANGE KEYPAD IC ITS PRISE IS ONLY 20.00
BUT THE SHOP KEEPER SAYS ITS PRISE 200 TO 250
IDRISH 911
Oct 22, 2010 | Nokia 5310 Cellular Phone
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
What does error 1203 mean on my lexmark A4270 when trying to receive a fax?
i think is code error for cartouche try this solution i hope to be helpful :
  1. Retirez les cartouches d'impression, puis fermez le couvercle du chariot des cartouches.
  2. Débranchez le cordon d'alimentation de la prise de courant.
  3. Rebranchez le cordon d'alimentation à la prise de courant.
  4. Si le voyant button_power_0.jpg n'est pas activé, appuyez sur button_power_0.jpg.
  5. Réinsérez les cartouches.
Si l'erreur ne réapparaît pas, le problème a été corrigé.
Si le problème réapparaît, une des cartouches ne fonctionne pas correctement. Suivez la procédure ci-après pour déterminer quelle cartouche ne fonctionne pas correctement.
  5. Réinsérez la cartouche noire (ou photo).
  6. Si l'erreur :
    • réapparaît, remplacez la cartouche noire (ou photo) par une cartouche neuve.
    • ne réapparaît pas, réinsérez la cartouche couleur.
  7. Si l'erreur réapparaît, remplacez la cartouche couleur par une cartouche neuve.
Aug 31, 2009 | Lexmark Office Equipment & Supplies
The remote does not work
have you dropped it? some times the infrared pickup becomes dry jointed.prise controller apart check for loose components by moving them resolder ir needed check conections at battery box if all ok ic could have failed .a last resort trick that as worked for me a few times is leave batteries out overnight it resets its self .good luck farr 64
Apr 30, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Ringtone to nokia 1100
i don't know but some mobile shops send them with very low prise try to go to a mobile shop they can work this out
Mar 24, 2009 | Nokia 1100
Changing Door Mirror Glass XJ6(X300)
Hi
You need to put on a pair of gloves, and safety glasses. (Safety First !)
Prise off the broken mirror from the plastic base that it is stuck too.
Give the plastic a clean with nail polish remover or similar.
Peel off the backing on new mirror glass, and carefully stick it on.
Good Luck !
Don´t forget to FixYa Rate Me Please !
John.
Feb 05, 2009 | 1998 Jaguar XK8
My n70. when i received a call there's no sound or dial?
Replace the inbuilt earpiece. Many Nokia earpieces are identical and readily available.
Remove Battery.
Remove the front cover. Prise out the earpiece from the back of the casing. Replace with new one. clean contacts on motherboard with isopropyl alcohol. Reassemble.
If this does not work the sound IC on the board is most likely damaged and you will need to sent it to a repair shop.
Hope this helps
Jan 26, 2009 | Nokia N70 Cellular Phone
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
