Question about Mitsubishi WS-55511 55" Rear Projection Television
WHAT DO YOU CALL IN THIS PHENOMENON WHEN THE COIN BECOME DIRTY WHEN IT IS MARK WITH THE FINGERS
    Scholar:
  • 113 Answers
Contamination of Convergence
Posted on Mar 27, 2011
Number "6" doesn't work making it impossible to dial out for any phone number with a "6". Any suggestions other than replacing the entire system?
Just a guess, but I would say that the number 6 pad is not making good contact with the circuit board. After time, the contacts on the back of the number will become dirty from the oil on your fingers. If you can take the phone apart, you can clean the contacts on the circuit board with an eraser and the back of the number pad with rubbing alcohol.
May 12, 2016 | Lands Phones
How to properly clean old coins
If they are dirty and you just want cleaned, use dish soap and hot water.
If the coin is antique or has value because it's old. Don't do anything.
You put any scratches on it while you clean, the value goes down BIG TIME!
Oct 14, 2014 | Retail Supplies
Battery not recharging when put in remote holder Logitech 850
This is a common problem for these remotes. Constant handling of the remote results in dirty charging contacts located on the bottom of the remote. Oils and acids from your fingers and hands also dirty the charging contacts. Also the contacts on the charging cradle can become dirty. I would recommend cleaning BOTH the charging contacts AND the cradle contacts using a Q-tip and some good quality rubbing alcohol.Be careful to just wet the Q-tip and gently scrub the contacts only. Careful regular maintenance should help you resolve this problem. Also you could check the Logitech website for recommendations on how to clean their equipment. Good Luck!
Jan 05, 2011 | Televison & Video
Bushnell banner lite site, how do you change the battery?
The battery is located inside the rotary switch on top of the eyepiece lens housing.
You have to grip the lower half of the switch with a few fingers of one hand and turn the cap off counter-clockwise with a coin inserted into the coin slot of the cap.
After you've replaced the battery (CR2032) put a very tiny amount of silicone grease on the O-ring on the cap, then replace the cap carefully avoiding cross threading the cap. You don't have to tighten it very much, just make sure the o-ring seats tightly.
Mark the Gunsmith
Dec 26, 2009 | Bushnell Banner Rifle Scope 3-9X 50...
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Coin is stuck
Does it become quiet for awhile after the coin is removed? I can't imagine how a coin lying in the bottom is making any kind of noise. There is no way for a coin to be trapped on the outside of the drum. It might, if it got past the lint filter and worked it's way into the blower housing, make an occasional 'clink'. Does the lint filter have any sizable holes in it? Do what these techs have done and see what you find.
Aug 26, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
CMOS Error
Usually you will find your CMOS battery somplace on the motherboard inside your PC. Before opening the PC though make sure you will not be voiding any warranties that you may have had when you bought it.
Some CMOS batteries have a small screw clasp that holds the battery in but most you can just pop out and then push the new one back in.
The most common battery type is a flat watch battery type size 2032, but it would pay to check before you go out and buy the replacement.
Hope this is helpful.
Oct 24, 2007 | Monarch Paxar Pathfinder UltraGold 6037...
Mitsubishi WS-55511 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
