Question about Western Digital My Book Essential WDBACW0020HBK - Hard drive - 2 TB - external - SuperSpeed USB Hard Drives
The led is light on but the hdd don't working(don't rotate the platan i think becouse is no sound inside)When i conect to system message apears "this usb can transfer information faster on usb 3.0.... but don't apears in my computer. I buy that hdd 3 days ago. Thanks in advice!
  • 11,800 Answers
Return it, the disk is defective. Do not try to fix it yourself - you can't and that will only void the warranty.
Posted on Mar 27, 2011
HELLO...MY HDD LED IS NOT BLINKING ON MY PC BUT WHEN I CONECTED TO MY FRIEND'S PC IT WORKED ......THE GREEN LIGHT IS WORKING PERFECTLY WHEN I CONNECT IT TO THE HDD LED POINT IT BLINKS BUT THE RED
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
Jun 11, 2012 | ASUS Computers & Internet
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
When i start the computer the monitor doesnt go and the red light indicating an error apears. what that can be please?
Dear User,
Please refix the is display cable properly and check if the issues resolves.
Kindly check if any beep sound comes. To check is the system board is fine. Please press the Num Lock for 2-3 times and check if it responds(Led On/Off)
To check the monitor status, please remove the display cable which is coming from monitor and connected with System(Cpu), if it displays the message on screen then it passes the monitor test and indicates that Monitor is fine.
Please share the result.
Regards,
Tech_Compu
Feb 22, 2011 | Computers & Internet
Hoe to install a diferent windows on a DELL
If HDD makes shshshsh.... or spinning sound or generates heat, your HDD might be ok. Next Try with XP sp2 cd. If it again cant detect HDD, go to BIOS setting and watch if the HDD is showing it's status. If Bios can not detect HDD check HDD cable and power cable inserted in HDD. Replace them if needed. Format the HDD with another PC. If you still have problem replace HDD with new one. One thing you might use your corrupted HDD as a slave drive later, i hope.
Keep informing.
Feb 23, 2009 | Dell XPS 600 PC Desktop
Netgear wirless router
you would need to know the ip adress put it into the browser. Then you would need to know the user name and password. it may ask for this info. Then you would look through the setens for a WEP password once you creat it rite it down somewhere so you can enter it on all the computers that conect wirlessly.
Jan 04, 2009 | NetGear SUPER-G WGT624 Wireless Router...
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Won't boot or start, fans and leds work
Are you hearing any beeps when you start it up?
Dec 17, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Western Digital My Book Essential WDBACW0020HBK - Hard drive - 2 TB - external - SuperSpeed USB Hard Drives Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
