Question about Refrigerators
My frigider is working but it doesnt seems to be cooling things
  • Kelly
    Kelly Mar 27, 2011
    We need your "make and model" number PLEASE so we can help you. Otherwise a genric response may not apply to your unit. Help us help you.
    Thanks for choosing FixYa,
    Kelly
Frigidaire ED5GTFXKQ02 not working
First make sure its input power supply is as per required coming or not if its OK then check thermostat device it may can faulty kindly check it if its required then need to replace it .
Hope answer the question
Aug 17, 2016 | Frigidaire Refrigerator Replacement Frigid...
Air Conditioner not dripping
your relative humidity outside and in is low so it's not condensating on the coils is the only thing I can think of.
Jan 14, 2018 | Amana Heating & Cooling
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
White Westinghouse ( Model# MRT 18FNEWO
Nov 24, 2011 | Refrigerators
Hello my car is using allot of water and my cooling fan doesnt seem to be working are these problems related
Yes they are likely related. The 1st thing you need done is to have a pressure test run of the cooling system to determine the cause of the coolant loss and to check the cooling system for rust and or a clogged radiator. If you have electric engine cooling fans they need to be tested as well to determine if they are functioning correctly. Any well equipped repair shop can run these tests for about 1 hour labor charge.
Jul 06, 2011 | Ford Escort Cars & Trucks
I have a brand new frigid air cinditioner and it is not cooling, i got it 2 days ago and it's on 24/7
If you have a unit that has stopped cooling in a couple of days... tkae it back and get another one...you got a lemon...
do not mess with it or tear it apart... just put it back in the box and return it for another one...
heatman101
Aug 31, 2010 | Frigidaire FAC084N7A Air Conditioner
I have a Frigidate upright frost free freezer and have noticed water coming out from underneath the unit. What is causing this to happen...food is still frozen
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
