Question about Ovens
My Westinghouse wall oven model PXL688W will not heat. Can I get a new element and change it myself? Is it difficult? Belinda Monery
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
huuum
  • 750 Answers
SOURCE: Oven heating element
Hello rvready
Welcome,
You said, We have an OLD (1950-60) Frigidaire wall oven, model # RBG-94. Bottom heating element has gone out. Oven is still in good shape so we'd like to be able to find an element replacement, but have had no luck finding one.
unfortunately,
I am not able to find this part either.
Anywhere. This oven is to old for parts. But most important is that it is causing you high utility rates!
Today's appliances save you the arm and the leg that such an old oven is costing you.
You have no idea how it is sucking your money out of your pocket!
It is unfortunate, that no one told you about this years ago!
You payed for more than one oven with your utility bill if you had it since it was new. My advice is do not put good money into bad!
Shop for a new one and see your bills go down.
my wife was telling me to replace the air and furnace for 7 years and I said, it's not broken. But it was over 20 years old. She was right, cause the new one saved me $100. a month!
That means I threw away $7000. in 6 years with my old world attitude.
Yes I am old fashion and always fix it!
But after 25 years of marriage. i finally realized she is a good evaluator and I was a fool to not appreciate her gift for all these years! And out tons more money than I told you about!
Hope I saved you some bucks with my real life stories!
Don't tell your wife!!!
Huuum
Posted on Oct 17, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Posted on Jan 31, 2010
I have a westinghouse wall oven, and the griller is not working. Are they easy to repair or do I require the services of a technician. Many thanks bernie
While they aren't that difficult to repair if you know something about appliances and are somewhat handy, you do need a multimeter to check whether the switch is the problem or if it is the element, which means you will me working with 220V that could ruin your entire day if you make a mistake.
Jun 09, 2011 | Ovens
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
I need the bottom heating element in an old westinghouse wall oven. the model # is OG25HXO
I am not certain what geographic region you are in but... Bake elements are often generic between brands. The key is to match up voltage, wattage, size, bends and terminals. Here are 2 pages of westing house elements:
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Range+%2f+Stove+%2f+Oven&Brand=Westinghouse&PartType=Element+or+Burner&Electrical=Yes
I tried searching using OG25HXO with little success even on westinghouse sites US and AU.
Thanks for choosing FixYa,
Kelly
Nov 18, 2010 | Ovens
Aqua GE Wall Oven SN10729 (Can't find a part number) 1950's-60''s
from the serial # it was made in september the second letter N is either 1956 or 1972.
take a look at this site it'll lead you to ge heating elements
see if there is one that resembles your's.
then call them. they are very helpful and may be able to tell you where the model # is. ask if what you're seeing might fit.
here's the link...
http://www.appliancepartspros.com/ge-wall-oven-heating-element.html
Hope this helps a little.
Happy New year
Jan 02, 2018 | GE Ovens
Oven not igniting and heating
Without the model number I can only give you basic information. If you are refering to the Glow Ignitor located in the center bottom rear of the oven concted to the burner tube, then this Ignitor could be bad and most tech's will change it first.
Even if it is glowing does not mean it is good.
For more detailed information please include as much information as postible and the Make and Model # off the machine.
Always unplug the machine when trying to service it.
Jan 10, 2010 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
The heating element failed on my W2451 wall oven. Is it something I can replace myself?
skill level ( easy ) 15 min . open door / remove racks / two screws . pull out slowly . two wires remove and reinstall to new element and reinstall . done . don't you feel better now .. mm
Nov 22, 2009 | Jenn-Air JJW8527C Expressions Collection...
Dec 27, 2008 | GE JKS05 Electric Single Oven
White Westinghouse built in oven not heating up.
go to RepairClinic.com
you'll need make & model #
Nov 15, 2008 | Ovens
Ovens Logo
156 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
