With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the tv, which is new.
    Top Expert:
  • Televison & ... Master
  • 75,386 Answers
Hello
You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
Posted on Mar 27, 2011
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
MY NEW HAIER 7" TV SAYS "NO DATABASE"! AND WHEN
Don't throw it away just yet. It's still under warranty so returning it would be far better than throwing it away ;)
As you can tune the cable channels OK, I suspect there is a problem with the reception from the antenna and the signal strength is too low. Please can you answer the following simple questions so that I can help you to solve this problem
1. What antenna are you using - indoor/rabbit ears or outdoor/roof antenna?
2. Do you have a good reception on another TV connected to the same antenna ?
If you are using an indoor antenna, try moving the TV to another location to see if you can get a better reception.
Please let me know the answers to the above questions. I will then be able to assist you further.
Regards,
BElectric
Jan 22, 2011 | Haier HLT71 7 in. Portable TV
I Cant Pick Up Any Signals On my Cobra 25 LTD 40-Channels Base CB Radio all i hear is nothing. no truckers saying stuff. i just get white noise i do have an antenna. it is a tv antenna w/ bunny ears :) i...
Your problem is probably the rabbit ears. They are for tv in the 54+
Mhz and CB is 27 Mhz. For simplicity, go to Radio Shack and get a back of the radio indoor antenna. They run under $20. If you want to get more; try a roof antenna or a 1/2 wave cb marine antenna outside.
Hope it helps.3
Tom
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
Unable to get consistent reception on ABC (channel 7 NY)
The antenna may be the problem in your case but I was getting New York 7 digital with a strong signal before the transition on June 12th and now I do not get any signal. I use a rather large VHF /UHF roof antenna mounted in my attic. The compass heading for NBC NY 4.1 is 169 deg and 18 mile from my location according to antennaweb.org. I get this channel with a strong signal. Comparably ABC NY 7.1 is 170 deg and 18.7 miles from my location and I do not get a signal. Perhaps ABC NY is having some problem with the transition. It does not make sense assuming the information of antennaweb.org is correct. BTW if and outdoor or attic mounted antenna is not an option I would recommend the following antenna. I used this for my friends? setup when she was having problems with rabbit ears. It also got some pretty high user reviews and is not expensive. It is for both indoor and outdoor applications. Good Luck! http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10901&cs_id=1090102&p_id=4730&seq=1&format=2
Apr 10, 2009 | RCA 20F514TD 20" TV
Mitsubishi vs-50603 does'nt get regular antenna chanels.
Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
michtech
Feb 16, 2009 | Mitsubishi VS-50603 50" Rear Projection...
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
